How to run airFoil2D exapmle in parallel on 4 cores?
I tried to run the airFoil2D example in parallel (4 core processor) using mpi but it didn't work. What's wrong? My approach: 1. Created a decomposeParDict (and set y to 0 since it's a 2D case) 2. Ran decomposePar 3. Changed the Allrun batch file decomposeParDict: numberOfSubdomains 4; method simple; simpleCoeffs { n ( 2 2 0 ); delta 0.001; } hierarchicalCoeffs { n ( 1 1 0 ); delta 0.001; order xyz; } metisCoeffs { processorWeights ( 1 1 1 1 ); } manualCoeffs { dataFile ""; } distributed no; roots ( ); //************************************************** ***********************// Allrun: #!/bin/sh # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions application=`getApplication` #runApplication $application mpirun -np 4 $application -parallel > log & |
Run Parallel
Since it's 2D case, and it's in xz plane, so maybe in the following line you can try:
simpleCoeffs { n ( 2 1 2 ); delta 0.001; } hierarchicalCoeffs { n ( 1 1 1 ); delta 0.001; order xyz; } Hope it works~:) |
Solution
Thank you! Also, the header text must be there.
Solution: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 4; method simple; simpleCoeffs { n ( 2 1 2 ); delta 0.001; } hierarchicalCoeffs { n ( 1 1 1 ); delta 0.001; order xyz; } metisCoeffs { processorWeights ( 1 1 1 1 ); } manualCoeffs { dataFile ""; } distributed no; roots ( ); // ************************************************** *********************** // |
