cantera-1.7.0 ,openfoam1.7.1
1 Attachment(s)
Hi ,
I have attached my errors after i moved all necessary source files in hannes repository from libextensions to generateFGM folder in order to generate the flamelet lookupt table after successful compilation. please help me, Thanks, Farshad |
Greetings Farshad,
Although I would like to at least help you out with the build process, I have no clue as to what steps you have taken to get to the point you got to get that output you posted. If you can detail a bit the steps you've taken for getting the files you are using, how you are trying to build them and with which OpenFOAM version, perhaps I can at least help out with the build process. Best regards, Bruno |
