Suitable solver for Air/Air flow with different temperatures
Old   January 18, 2011, 05:33
Default Suitable solver for Air/Air flow with different temperatures
cjm
Carl
cjm is on a distinguished road
Hallo community,
I have a rather simple question. I have a setup which can be seen in the picture. A standard 3D air flow through a domain with a XVelocity of 10m/s and a funnel like geometry with an air inlet on top with a higher velocity and much higher temperature (500K). My question is what the most suitable solver might be in OF for such a case - e.g. which can solve turbulent flow with changing temperatur? After that calculation I want the second flow to be a different phase (exhaust like particles). Which solver would suit best for that?
Thanks for any hints..cjm
cjm is offline   Reply With Quote
Old   January 20, 2011, 04:17
Nakul
nakul is on a distinguished road
As far as first simulation is concerned I think any incompressible solver would be suitable. I did something similar for compressible flow and used rhoCentralFoam with turbulence and there wasn't any problem.
For the multiphase run based upon the above thinking you may try some standard multiphsase solver but I have never done multiphase flow so I can't be sure.
nakul is offline   Reply With Quote
Troubleshooting Unsteady Incompressible Flow Solver dandalf Main CFD Forum 0 November 15, 2010 10:55
Solver for a turbulent flow in a tube sErik OpenFOAM Running, Solving & CFD 1 December 8, 2009 10:33
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
