Home > Forums > OpenFOAM
simpleEngine in OF1.6-ext
Old   January 17, 2011, 10:05
Default simpleEngine in OF1.6-ext
Dalibor
jajcevic is on a distinguished road
Hello everybody,
I am testing simpleEngine tutorial in OF 1.6-ext., but until now without success. I suppose that settings in dynamicMeshDict are not correct. I am using icoDyMEngineFoam solver.
Attached you will find my grid and case settings.
Thank you!
Dalibor
jajcevic is offline   Reply With Quote
Old   January 19, 2011, 07:17
abminternet is on a distinguished road
it is your liftProfilefiles, I had the exact same error and it took me a lot of time to find it. your syntax should be:
x y
x y
x y
x y
x y
I am also working on OF 1.6-ext trying to set up the simpleEngine case, but with sonicTurbDyMEngineFoam, which uses compressible flow, and am having some troubles with some Temperatures being =0, which causes division by 0 :S so I would be very interested in your progress!!
abminternet is offline   Reply With Quote
Old   January 19, 2011, 08:26
Dalibor
Thanks for information. It is correct, the lift profiles were incorrect.
I have also changed settings in fvSchemes and fvSolution files in order to start calculation. But, at about -200CA the calculation is stop due to following error:
--> FOAM FATAL ERROR:
Error in point ordering: mixed used and unused points at the end of point list.
Last used point: 1284 (-0.01 0.0025 0)
First unused point: 1285 (-0.01 0.0025 -0.00875)
and point 1375 (0.04 0.0025 -0.013125) is used by a live face.
Face 1140 4(1218 1375 1386 1219) with points 4((0.04 0.0025 -0.00875) (0.04 0.0025 -0.013125) (0.04 -0.0025 -0.013125) (0.04 -0.0025 -0.00875))
Face 1141 4(1375 1376 1387 1386) with points 4((0.04 0.0025 -0.013125) (0.04 0.0025 -0.0175) (0.04 -0.0025 -0.0175) (0.04 -0.0025 -0.013125))
Done.
From function void polyMesh::initMesh()
in file meshes/polyMesh/polyMeshInitMesh.C at line 174.
FOAM aborting
That is not all. ParaFoam cannot read the data, only at -270CA (initial data), so that I cannot see the grid moving process.
Do you have any ideas?
My next test case will be with sonicTurbDyMEngineFoam solver, because the incompressible solver for IC-engine simulation is not useful.
Once again, thanks for your reply.
Old   January 20, 2011, 05:43
Hmm sorry I can't help you there yet, I was running your case and got the exact same error. If I figure it out Ill let you know, maybe you could do the same
Old   January 20, 2011, 05:46
oh by the way, I didnt install paraFoam when i installed OF 1.6-ext, so I use paraview 3.8.0, and I was able to open it with it, maybe you could try that
Old   March 22, 2011, 06:46
RalphS is on a distinguished road
Dear Dalibor ,
Have you found a solution to your problem?
I also want to simulate an engine.
Regards,
Ralph
RalphS is offline   Reply With Quote
Old   March 24, 2011, 07:48
ok, i am not quite sure, but i think if you play with the min max cell thickness values and deformAngle, you could solve the problem.
Old   April 3, 2013, 05:07
Sasan Ghomi
sasanghomi is on a distinguished road
Done.
FOAM aborting
Hi Dalibor
I have a same error for engine simulation...
Last used point: 2296 (-0.013 0 0.00107703)
First unused point: 2297 (-0.013 -0.0009 0.00107703)
and point 2298 (-0.037 -0.0100087 0.00107703) is used by a live face.
Face 2019 4(2298 2318 2331 2329) with points 4((-0.037 -0.0100087 0.00107703) (-0.037 -0.0100087 -0.00107703) (-0.037 -0.00969634 -0.00107703) (-0.037 -0.00969634 0.00107703))
Done.
FOAM aborting
Aborted (core dumped)
have you overcome this problem yet?
what is the origin of this error?
I appreciate any help from you.
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Thread Tools
Trackbacks are On
fortran dll ollimarc CFX 3 October 19, 2010 14:26
couple OF with ext. structural solver: how to interpolate BC matteoL OpenFOAM 0 July 29, 2010 08:30
Arbitrary crack propagation using OF1.6 gilav OpenFOAM Programming & Development 1 May 22, 2010 06:52
compressibleInterDyMFoam on OF1.6 lucadauria OpenFOAM Running, Solving & CFD 2 February 24, 2010 21:18
InterTrackFoam in OF1.6? M_Harrer OpenFOAM Running, Solving & CFD 2 November 17, 2009 10:43
