Linux kernel performance enhancement
Hi all,
I thought I would let you all know about an upcoming linux kernel feature. Its called Transparent Hugepage Support. It improves performance by using larger virtual memory pages supported by processors. This improves performance by reducing TLB misses and table walks. It has been recently incorporated into the linux-mm kernel and at some point soon make it into the main branch. http://lwn.net/Articles/419933/ current code http://git.kernel.org/gitweb.cgi?p=l....git;a=summary I did a simple benchmark with it on the combustion/engineFoam/kivaTest tutorial with a single core on my Turion x2 processor in my laptop. I get a consistent 1% speed improvement over multiple tests. time without it enabled real 16m43.317s user 16m41.611s sys 0m1.460s time with it enabled real 16m32.794s user 16m30.629s sys 0m1.633s Yes it only saved 10.5 seconds of run time but that was done without any changes to the application executable. I acknowledge that 1% isn't a lot but I would expect this to provide more of a boost on multicore test runs because there would be less memory bus contention. I would also expect better performance on more advanced processors since they have more huge page TLBs. Other cases also might show more of an improvement. (Note some software shows a 20% improvement) Since some cases can take several hours to run (my record so far is 100 hours) I figure a 1% speed bump would be welcome. I would be interested to see others performance test results on real systems. |
