-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Blow of compressible solver while using K-epsilon model in openfoam (http://www.cfd-online.com/Forums/openfoam/84278-blow-compressible-solver-while-using-k-epsilon-model-openfoam.html)
Amit Mathur January 25, 2011 07:57
Dear all,
I am trying to run a simulation for a compressible flow in a pipe by using the K-Epsilon turbulence model in the version 1.7 from OpenFOAM.
For this simulation, I use a compressible solver : rhoSimpleFoam and I have defined the following boundary conditions :
- Inlet : pressure-101325
- Outlet : pressure-98383
My problem is that, after some iterations, the epsilon start bounding for very high values like 1e70. Afterwards solver blow and stop working.
I used K-epsilon, resizable K-epsilon, RngKE but problem remain as it is.
I already have remeshed my geometry to try to get a better mesh (orthogonal cell at the walls) but the problem persists.
I already have increased the number of nNonOrthogonalCorrectors but the problem persists.
To reproduce my problem, I have meshed a straight pipe and used the same setup. With the straight pipe (hexahedra), there is no problem and with a complex geometry (hexcore mesh from Tgrid), I do not understand what happens.
I presume that there are some problems with my setup but I do not understand where.
Afterwards i applied K-Omega-SST model. That time solver produce results but i dont why K-epsilon is not running.
So my question is why K-epsilon model in compressible flow is not working with Tet mesh in openfoam?
Thanks.
Best regards,
Amit
nakul January 26, 2011 11:35
It seems possible that there might be some problem with your BC.
Do you really need a fixed value of pressure at outlet? Try changing outlet pressure to zeroGradient,
What is the flow velocity and temperature?
Specify more details of your case.
Amit Mathur January 27, 2011 01:06
problem in rhosimplefoam using k-epsilon model
Hi nakul,
Thanks for reply.
Flow in the geometry is pressure driven so the inlet at higher pressure and outlet at lower pressure. The velocity bc is zero gradient at both outlet and inlet. The temperature is fixed at 293 K for both inlet and outlet. I tried the same BC for hex mesh it works properly for K-epsilon model but in Tet mesh its fail even mesh quality is good.
nakul January 27, 2011 02:30
Do a checkMesh on your tet mesh and see what you get.
Try reducing Co no. and use first order schemes in fvSchemes.
See if is helps.
Amit Mathur January 27, 2011 03:28
Dear Nukul,
I am using steady compressible solver (rhoSimpleFoam), there is no need of co no.
I am sending you the cheak Mesh result. Ots seems to be Ok.
Thanks
Checking geometry...
Overall domain bounding box (-0.917934 -0.649145 0.434051) (0.147203 0.0148634 0.759144)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-9.87366e-16 -8.81665e-17 3.83878e-17) OK.
Max cell openness = 7.52033e-16 OK.
Max aspect ratio = 38.487 OK.
Minumum face area = 9.7289e-09. Maximum face area = 0.00235134. Face area magnitudes OK.
Min volume = 2.21352e-12. Max volume = 0.000103724. Total volume = 0.0505074. Cell volumes OK.
Mesh non-orthogonality Max: 71.3198 average: 22.1898
*Number of severely non-orthogonal faces: 1.
Non-orthogonality check OK.
<<Writing 1 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 3.35511 OK.
RalphS January 27, 2011 03:38
I tried for two months rhoSimpleFoam, wasn't easy to get a stable simulation.
Right settings in fvSchemes and fvSolution are very important.
relTol, relaxationFactors, divSchemes
In my opinion try to set:
fvSolution:
solvers
relTol 0.1;
relaxationFactors
p 0.01;
rho 0.01;
U 0.5;
h 0.1;
k 0.1;
epsilon 0.1;
When it works, you could set the factors higher.
fvSchemes:
divSchemes
div(phi,U) Gauss vanLeerV;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
I would use realizable k-Epsilon.
Are your velocity high?
Why you have fixed temperature at inlet and outlet?
Regards,
Ralph
Amit Mathur January 27, 2011 05:36
Dear RalpS,
Thanks for replying. I adjust the system schemes, solution and relaxation factor
according to you. But the problem is same the solution stops for KE. Well resizable KE
is already running successfully but it is not converging. While using K-Omega SST model the solution is converged and max Velocity is 130m/s.
For K-Epsilon the problem is remain as its is
Thanks
RalphS January 27, 2011 06:08
Have your tried to use a start solution for KE?
With realizable KE and K-Omega SST the simulation runs without stopping?
Why you want to use KE then?
Amit Mathur January 27, 2011 06:14
Dear RalpS,
The solution runs successfully in Simple Foam (incompressible) but fails using
rhoSimpleFoam (compressible) while using K-epsilon.
The initial value of K-E from turbulent intensity and mixing length.
nakul January 28, 2011 03:59
Hi Amit,
Since you are getting converged solutions with k-omega that means your case setup is correct.
But if you want to have solutions with k-epsilon try the following and see if you are getting any convergence:
1 Are you using the fvSchemes proposed by Ralph? If yes then make the divScheme for (phi, U) as upwind also. Use upwind scheme for all divSchemes as it is first order.
2 Run the case with turbulence switched off and solve for the flow field. Then use this converged solution as initial condition for turbulence on.
Hope this helps you. If you still face problems then upload your case and I will try to have a look if time permits.
olivierG January 28, 2011 05:10
Did you run in parallel ? Because there is some trouble with turbulence (k-epsilon) and DILUPBiCG (see http://www.cfd-online.com/Forums/ope...tml#post246561 )
So you may try to switch to smooth solver for U, k and epsilon, and keep Gauss upwind for div(phi,k) and div(phi,epsilon)
Also try Gauss linearUpwind cellLimited Gauss linear 1; for div(phi,U)
Regards,
olivier
Amit Mathur January 28, 2011 06:29
Hi Nukul,
Thanks for replying. I made changes what so ever you suggested to me. But the problem is remain as it is. The solution blow of after some iterations.
It runs good while making turbulence off and starts converging. I solve the flow field
without turbulence model. Its runs and converged up to 10e-3. And then "on" the turbulence model. But again solution is blow after 9 or 10 iterations.
Thanks
olivierG January 28, 2011 06:34
OpenFoam is sensitive to initial values, specialy with turbulence one.
Show your k and epsilon file in 0/ dir.
What is your initial conditions ?
Regards,
olivier
Amit Mathur January 28, 2011 06:59
Hi OlivierG,
Thanks for reply. I runs solver in parallel. But in series the problem of blowing is not solved. I changed the solver and schemes settings as you suggest to me but the problem as its is.
Here below i am showing my k and epsilon file.
K-
FoamFile
version 2.0;
format binary;
class volScalarField;
location "0";
object k;
dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 1;
boundaryField
wall
type compressible::kqRWallFunction;
value uniform 1;
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.01;
value uniform 1;
outlet
type inletOutlet;
inletValue uniform 1;
value uniform 1;
symplane
type symmetryPlane;
and Epsilon-
dimensions [0 2 -3 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type fixedValue;
value uniform 1;
symplane
type symmetryPlane;
wall
type compressible::epsilonWallFunction;
value uniform 1;
olivierG January 28, 2011 07:15
1) for outlet, try zeroGradient for k and epsilon
2) for inlet, k is ok, but for epsilon you can use "turbulentMixingLengthDissipationRateInlet"
In any case, for k/epsilon, you may also try fixedValue at inlet
3) You use initial value 1 for k and 1 for epsilon: are you sure this is a correcte estimation ? (i think no)
check http://www.openfoam.com/docs/user/ca...#x5-290002.1.7 at chap2.1.8.1
Regards,
Olivier
Amit Mathur January 29, 2011 03:46
Dear OlivierG,
Thanks for reply.
I made the k and epsilon boundary condition to zero gradient at outlet and for inlet epsilon
turbulentMixingLengthDissipationRateInlet is used. The mixing length is 0.00821.
It is difficult to predict the correct value of k-epsilon for boundaries because the flow is pressure driven.
Inlet-101325
outlet-98383
But on the basis of successful simulation of model using K-omegaSST model which is previously done. The max velocity is 130m/s. As reference of that velocity 130m/s and using intensity 1% i calculate k=2.535 and epsilon=4.368.
But the things are not working, the solution is just blow off after 5 iterations.
thanks
novakm October 6, 2013 11:09
Originally Posted by Amit Mathur (Post 292742)
Dear OlivierG,
Thanks for reply.
Inlet-101325
outlet-98383
thanks
Hi amit.
I am facing same issue. Did you find out a reasonable solution for such a setting?
Best regards
Martin
