Difference between 'internalField' and 'boundaryField'?
Like Tree35Likes
Old   January 26, 2011, 07:50
Post Difference between 'internalField' and 'boundaryField'?
Felix W.
Rusty Velo is on a distinguished road
Dear OFoamers,
as a new user of OpenFoam, I've maybe a very simple question .. but the OF-tutorial doesn't give a satisfying answer to me and I become more and more confused (as I tried to make some 'try and error calculations').
What does 'internalField' in e.g. a U-file describe ? And what is the difference between the 'internalField' and the 'boundaryField' (in detail) ?
Thanks in advance,
felix
omarozo, mizzou, granzer and 1 others like this.
Rusty Velo is offline   Reply With Quote
Old   January 26, 2011, 08:31
Nima Samkhaniani
nimasam is on a distinguished road
consider pressure (p), it is defined as volScalarField
means it defines in center of each cell in domain. domain has two parts : domain content (internalField) and domain surrounding (boundaryField).
p.boundaryField() give you access to value in boundary, value in boundary would be surface center value. its helpful when you need the maximum, min, sum or average the value of a patch, so it returns a surfaceScalarField.
p.internalField() returns a scalarField (im not sure, check it ) , so it can be useful when you want to deal with internal value and keep boundary conditions unchanged.
nimasam is offline   Reply With Quote
Old   January 26, 2011, 08:36
Dominic
351Cleveland is on a distinguished road
Hi felix,
I'm quite new to OpenFoam myself, but I can give a shot at explaining the internalField condition.
For the velocity, U, the internalField characteristic is used to determine the properties of the fluid inside the computational domain. e.g. if the fluid is stationary and there is no velocity in any direction, the value will be uniform (0 0 0), whereas if we are addressing kinetic energy (scalar) and the initial conditions suggest there is some present, the value will be uniform x.
In short, as far as I know, (and hopefully right), this condition is simply used to assign the appropriate initial properties to the fluid not located at any of the boundaries.
Hope this helps.
Dom.
omarozo, alanaj5 and MaySea like this.
351Cleveland is offline   Reply With Quote
Old   January 26, 2011, 08:46
Nima Samkhaniani
beside if you just asking about U file in directory 0;
consider you are going to solve a differential equation you need to have boundary condition and initial condition, internalField defines initial condition it can be uniform or nonuniform and boundaryField defines boundary condtion which is mathematical boundary condition likes : fixed value ( means value in that patch is defined ) or zeroGradient ( gradient of the variable in that boundary is zero) look more in user guide
Old   January 26, 2011, 09:53
Felix W.
Hi Nima, hi Dominic,
thanks for your fast replies ! These are exactly my missing information..
Nima: At the moment I'm only looking at some old cases to get known with all the different possibilities for all the settings.. but be sure, that I'll also read further in the user guide !
kind regards,
felix
Old   August 7, 2012, 11:00
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Dear nima
Thanks for your clear description.
Could you please add also that what is the difference between dimensionedInternalField() and InternalField()?
I have the following equations. but when I am replacing the dimensionedInternalField() with InternalField() it gives the error. ( and there is no dimensionedboundaryField() ).
A.dimensionedInternalField()=min(scalar(0),B.dimen sionedInternalField()); A.boundaryField()=min(scalar(0),B.boundaryField()) ;
Best
Mahdi
Luttappy likes this.
mm.abdollahzadeh is offline   Reply With Quote
Old   August 7, 2012, 13:36
Nima Samkhaniani
you know variable has dimension, for example velocity dimension is {m/s}
OpenFOAM saves both variable values and its dimension,
so dimensionedInternalField() has besides value of InternalField(), its dimension too!
the error returns that you are going to compare a dimensionedvarible with a scalar,
it is not allowed, you should define your zero! as a dimensionedScalar with appropriate dimension
Old   August 7, 2012, 14:51
mahdi abdollahzadeh
Thanks nima
But i was meaning that this formula is ok!
but this one is not ok
A.InternalField()=min(scalar(0),B.InternalField());
meth likes this.
Old   August 7, 2012, 15:45
Nima Samkhaniani
and whats the error?
post the error here
Old   April 29, 2014, 12:40
CHARLES
CHARLES is on a distinguished road
I know this is an old thread but I have a question related to this subject...
I'm trying to write a forAll loop and I keep on getting errors no matter how I code it.
I tried coding it this way:
forAll(f1,celli)
    if (utau[celli] == 0.0)
    f1[celli] = exp(-0.5*xn[celli]*utau[celli]/nu());
    }else
    { f1[celli]= 0.0;
But that yields the following error:
 error: cannot convert ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘double’ in assignment
make: *** [Make/linux64GccDPOpt/SPLRRIP.o] Error 1
I have tried many combinations of .internalField() and .dimensionedInternalField() but I still get a similar error...
I understand that f1 is dimensionless, so I have also tried to use .value() instead of [celli] on xn and utau but when I do so, I get the following error:
SPLRRIP.C: In member function ‘virtual void Foam::incompressible::RASModels::SPLRRIP::correct()’:
SPLRRIP.C:458:26: error: ‘Foam::volScalarField’ has no member named ‘value’
SPLRRIP.C:458:39: error: ‘Foam::volScalarField’ has no member named ‘value’
What am I doing wrong?
Here is how I have defined utau, f1 and xn.
    xn
        IOobject
            "xn",
            runTime_.timeName(),
            mesh_,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh_,
        dimensionedScalar("xn", dimLength, SMALL)
    utau
        IOobject
            "utau",
            mesh_,
            IOobject::NO_READ,
        mesh_,
        dimensionedScalar("utau", U_.dimensions(), 0.0)
    f1
        IOobject
            "f1",
            mesh_,
            IOobject::NO_READ,
        mesh_,
        dimensionedScalar("f1", dimless, 0.0)
   xn = wallDist(mesh_).y(); //Normal distance to wall
  const fvPatchList& Boundaries = mesh_.boundary();
    forAll(Boundaries, patchi) //loops through boundaries, patchi is the index
        const fvPatch& currPatch = Boundaries[patchi]; //indexed boundary definition (current patch)
        if (isType<wallFvPatch>(currPatch))
            utauw.boundaryField()[patchi] =
            sqrt
                            nu()*mag(U_.boundaryField()[patchi].snGrad())
            forAll(currPatch, facei)
                label faceCelli = currPatch.faceCells()[facei]; //indexed face in current patch
                // Assign utau[on indexed cell face] value from utauw[on boundary][at each boundary face]
                utau[faceCelli] = utauw.boundaryField()[patchi][facei];
            forAll(utau, celli) //assigns value of utau[at face] to utau[cells]
            utau[celli] = utau[faceCelli];
Thanks!
CHARLES is offline   Reply With Quote
Old   April 29, 2014, 13:14
dkxls's Avatar
Armin
dkxls will become famous soon enough
You are dividing by nu(). What is nu()? Is it a field? If so, then you need to access also for nu() the cell values.
In general it's a good idea to get a reference to the internal/boundary fields and loop through these ones. Something like this:
    scalarField& f1Cells = f1.internalField();
    forAll(f1Cells, cellI)
        f1Cells[cellI] = ...
    forAll(f1.boundaryField(), patchI)
        fvPatchScalarField& pf1 = f1.boundaryField()[patchI];
        forAll(pf1, faceI)
            pf1[faceI] = ...
babakflame and thosa like this.
dkxls is offline   Reply With Quote
Old   April 29, 2014, 13:26
CHARLES
Hello Armin,
I thought nu was the kinematic viscosity defined in constant > transportProperties. Since I'm running incompressible simulations, I assumed that nu() was just a constant value, which is why I wasn't trying to access the individual cell values.
However, I tried indexing nu():
forAll(f1Cells,celli)
    f1Cells[celli] = exp(-0.5*xn[celli]*utau[celli]/nu[celli]);
    }else
    { f1Cells[celli]= 0.0;
I get the error:
SPLRRIP.C:459:58: error: invalid types ‘<unresolved overloaded function type>[Foam::label {aka int}]’ for array subscript
If I try to include the "()" in nu(), while indexing:
    f1Cells[celli] = exp(-0.5*xn[celli]*utau[celli]/nu()[celli]);
    }else
I get :
SPLRRIP.C:459:60: error: no match for ‘operator[]’ in ‘Foam::incompressible::turbulenceModel::nu() const()[celli]’
Old   April 29, 2014, 13:44
dkxls's Avatar
Armin
Originally Posted by CHARLES View Post
Apparently, nu() is not a field. I haven't checked the source code and I usually don't deal with the incompressible code anyways.
No idea, what goes wrong in your code. Are you sure the error is related to the code you posted initially? Maybe you recheck the line numbers in the error message and source code.
Old   April 29, 2014, 14:01
CHARLES
Thanks anyway Armin!
I know that the error is caused by the way that I am assigning the value to f1.
OpenFOAM doesn't like the f1[celli]=exp(...)
The reason (as far as I understand it) is that f1 is a field, but exp(...) returns a double. So, I'm trying to assign a 'double' to a cell within a field.
I think I may have figured out a solution to the initial problem... now I have another one
Coding it in the following way compiles (I know I should create a label but I'm testing for now):
forAll(f1,celli)
    f1.internalField() = exp(-0.5*xn[celli]*utau[celli]/nu());
    }else
    { f1.internalField()= scalar(0.0);
Now the problem is that the simulation will stop on the first iteration with the following error:
Starting time loop
Time = 1e-05
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 1.36617e-07, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 1.36614e-07, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.999805, Final residual = 9.67079e-07, No Iterations 531
time step continuity errors : sum local = 3.21009e-14, global = 1.1476e-17, cumulative = 1.1476e-17
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Argument of trancendental function not dimensionless
[0]
[0]     From function trans(const dimensionSet&)
[0]     in file dimensionSet/dimensionSet.C at line 424.
[0]
FOAM parallel run aborting
[0]
Old   April 29, 2014, 14:20
dkxls's Avatar
Armin
Does that make sense?
No it doesn't make sense.
f1 may be a field, but you can very well assign 'double' values to a cell. In fact when you do
f1Cells[cellI] = 3.141592;
you assign a 'double' to the cell.
Well, the solution for you is to bisect your code. Meaning, start with assigning 'double' values (e.g. 3.141592) to your cells and see if it compiles. If that works, add step by step more functions and see where it starts to go wrong.
Good luck!
Old   April 29, 2014, 14:25
dkxls's Avatar
Armin
forAll(f1,celli)
    }else
That looks wrong!
Where is that code anyways? In a solver or a library?
Maybe you try to switch back to my initial example with the reference to the internal field and remove the nu(). Does that compile?
Old   April 29, 2014, 16:01
CHARLES
Armin,
The code is part of a turbulence model (LRR).
I tried doing
f1Cells[cellI]=3.141564
and the code compiled.
I removed nu() and substituted it with it's numerical value and it compiled and ran! So the whole problem was being caused by nu().
How would you access the value of nu so that the loop will adopt the numerical value for the current simulation?
The reason why I am confused is that I am able to access nu whenever it is outside of a loop.
For example, if I have
f1=exp(-0.5*xn*utau/nu());
there is no problem.
The problem arises when nu() is used in the loop...
Old   April 30, 2014, 05:52
dkxls's Avatar
Armin
This brings me back to my first questions:
Look up the return type of nu() and you will have the solution to your problem. Random testing will just waist your time here. My guess is that it is a tmp-field...
Old   April 30, 2014, 12:59
CHARLES
That is a great question... After looking in transportModels/incompressible/viscosityModels/Newtonian I have learned that nu() is in fact a tmp field:
  // Member Functions
        //- Return the laminar viscosity
        tmp<volScalarField> nu() const
            return nu_;
Is there anything in particular that you could suggest to fix this problem? As you can tell, I have no clue what is going on! :/
I don't understand why nu() can be accessed in a non-loop way but not from within a loop.
Thank you so much for taking the time to work through this with me.
Old   May 2, 2014, 06:07
dkxls's Avatar
Armin
It is quite useful to learn how "tmp" works when your get to the "advanced" programming in OpenFOAM. See here:
http://openfoamwiki.net/index.php/OpenFOAM_guide/tmp
http://www.cfd-online.com/Forums/ope...acro-pain.html
A fix to your problem would be something like this:
const scalarField& nuCells = nu()().internalField();
In a loop you can then access the cell-values as usual:
f1Cells[cellI] = 3.141564*nuCells[cellI];
Milica and cryabroad like this.
boundaryfield, internalfield
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 08:07
boundaryField vs. internalField sebonator OpenFOAM 10 January 24, 2011 16:43
solidWallHeatFluxTemperature at the solid solid interface in chtMultiRegionSimpleFoam maddalena OpenFOAM Running, Solving & CFD 43 January 11, 2011 02:39
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 06:22
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
