[Sponsors] | |||||
#21 |
Leon Eilders
Rep Power: 4 ![]() |
in reality there would be an outlet. that is what i want to simulate.
#22 |
Leon Eilders
Here we are again... Adapted my snappyhexmesh untill it passed the checkmesh. I used a higher refinement and set the maxskewness to 0.5. Giving quite good results.
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1798140
internal faces: 1710919
cells: 561545
boundary patches: 8
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 460753
prisms: 30962
wedges: 0
pyramids: 0
tet wedges: 124
tetrahedra: 0
polyhedra: 69706
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
maxY 210 249 ok (non-closed singly connected)
minX 210 249 ok (non-closed singly connected)
maxX 210 249 ok (non-closed singly connected)
minY 210 249 ok (non-closed singly connected)
minZ 799 974 ok (non-closed singly connected)
maxZ 797 972 ok (non-closed singly connected)
stlSurface_Sail 81905 85179 ok (non-closed singly connected)
stlSurface_Suck 2880 3844 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-10.75 -10.3595 -5.52462e-06) (10 10 30)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (2.53646e-16 1.24211e-16 -1.78792e-16) OK.
Max cell openness = 9.50189e-16 OK.
Max aspect ratio = 13.2989 OK.
Minumum face area = 6.84828e-05. Maximum face area = 16.8984. Face area magnitudes OK.
Min volume = 2.70464e-06. Max volume = 33.7968. Total volume = 12544.9. Cell volumes OK.
Mesh non-orthogonality Max: 62.8324 average: 8.96609
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.2706 OK.
Mesh OK.
End
Time = 70
smoothSolver: Solving for Ux, Initial residual = 0.00795705, Final residual = 7.13943e-05, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.0110534, Final residual = 0.000101015, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.101537, Final residual = 0.000387196, No Iterations 5
GAMG: Solving for p, Initial residual = 0.0691879, Final residual = 0.000240485, No Iterations 4
time step continuity errors : sum local = 0.000322106, global = -2.5441e-06, cumulative = -0.000247151
smoothSolver: Solving for epsilon, Initial residual = 0.384302, Final residual = 0.000275313, No Iterations 2
bounding epsilon, min: -577.335 max: 4.34232e+07 average: 272.56
smoothSolver: Solving for k, Initial residual = 0.0316469, Final residual = 0.000295912, No Iterations 3
bounding k, min: -1.23476 max: 3342.86 average: 0.483003
ExecutionTime = 260.45 s ClockTime = 261 s
forceCoeffs output:
Cd = 1.04372
Cl = 1.91814
Cm = -0.564935
forceCoeffs output:
Cd = 0.966914
Cl = 1.87556
Cm = -0.564033
forceCoeffs output:
Cd = 0.0768036
Cl = 0.0425825
Cm = -0.000902006
Time = 71
smoothSolver: Solving for Ux, Initial residual = 0.308738, Final residual = 0.0023828, No Iterations 5
smoothSolver: Solving for Uy, Initial residual = 0.167585, Final residual = 0.000735947, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.23801, Final residual = 0.00192168, No Iterations 4
GAMG: Solving for p, Initial residual = 0.0718548, Final residual = 0.000221095, No Iterations 4
time step continuity errors : sum local = 0.000302917, global = 1.43559e-05, cumulative = -0.000232795
smoothSolver: Solving for epsilon, Initial residual = 0.108878, Final residual = 0.00106995, No Iterations 4
bounding epsilon, min: -27638.7 max: 2.86248e+07 average: 249.215
smoothSolver: Solving for k, Initial residual = 0.271598, Final residual = 0.00251725, No Iterations 5
bounding k, min: -67.7914 max: 4138.36 average: 0.486237
ExecutionTime = 264.09 s ClockTime = 265 s
forceCoeffs output:
Cd = 1.24648
Cl = 1.95098
Cm = -0.468876
forceCoeffs output:
Cd = 1.16514
Cl = 1.90592
Cm = -0.467914
forceCoeffs output:
Cd = 0.0813401
Cl = 0.0450539
Cm = -0.00096219
Time = 72
smoothSolver: Solving for Ux, Initial residual = 0.999998, Final residual = 0.00776452, No Iterations 5
smoothSolver: Solving for Uy, Initial residual = 0.999999, Final residual = 0.00811549, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.00648876, No Iterations 4
GAMG: Solving for p, Initial residual = 0.674664, Final residual = 0.00246658, No Iterations 4
time step continuity errors : sum local = 74714.8, global = 2712.55, cumulative = 2712.55
smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.00265908, No Iterations 5
bounding epsilon, min: -1.75341e+13 max: 3.03906e+14 average: 8.17846e+09
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.00157535, No Iterations 2
bounding k, min: -2.28545e+11 max: 9.35617e+12 average: 1.09552e+08
ExecutionTime = 267.75 s ClockTime = 269 s
forceCoeffs output:
Cd = -1.93271e+07
Cl = -3.8579e+07
Cm = -6.25219e+06
forceCoeffs output:
Cd = -1.93341e+07
Cl = -3.85828e+07
Cm = -6.25209e+06
forceCoeffs output:
Cd = 6971.54
Cl = 3785.83
Cm = -98.9127
Time = 73
smoothSolver: Solving for Ux, Initial residual = 0.765646, Final residual = 0.00289439, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.797186, Final residual = 0.00462204, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.656947, Final residual = 0.00441734, No Iterations 4
GAMG: Solving for p, Initial residual = 0.999727, Final residual = 0.00550768, No Iterations 5
time step continuity errors : sum local = 41235.4, global = 17613.6, cumulative = 20326.2
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::LimitedScheme<double, Foam::limitedLinearLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam171/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::limitedSurfaceInterpolationScheme<double>::weights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam171/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::fv::gaussConvectionScheme<double>::fvmDiv(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/openfoam171/lib/linux64GccDPOpt/libfiniteVolume.so"
#6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam171/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#8 Foam::incompressible::RASModels::RNGkEpsilon::correct() in "/opt/openfoam171/lib/linux64GccDPOpt/libincompressibleRASModels.so"
in "/opt/openfoam171/applications/bin/linux64GccDPOpt/simpleFoam"
#10 __libc_start_main in "/lib/libc.so.6"
#11
created temporary '35degr2.OpenFOAM'
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-8;
relTol 0.01;
//smoother GaussSeidel;
smoother DIC;
nPreSweeps 0;
nPostSweeps 1;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
U
solver smoothSolver;
tolerance 1e-7;
relTol 0.01;
nSweeps 1;
k
tolerance 1e-6;
relTol 0.01;
nSweeps 1;
epsilon
tolerance 1e-6;
relTol 0.01;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0; //0; // 0, 1 or 2
pRefCell 0;
pRefValue 0;
relaxationFactors
p 0.3; //0.3;
U 0.7; //0.7;
k 0.7; //0.7;
epsilon 0.7; //0.7;
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear; //was 0.5
divSchemes
default none;
div(phi,U) Gauss GammaV 0.5; //was 0.5 1.0
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div((nuEff*dev(grad(U).T()))) Gauss linear;
//div((nuEff*dev(grad(U).T()))) Gauss linear faceMDLimited Gauss linear 0.85;
//div(phi,U) Gauss linearUpwindV faceMDLimited linear 0.68; //was 0.5 1.0
//div(phi,k) Gauss linearUpwind faceMDLimited Gauss linear 0.2;
//div(phi,epsilon) Gauss linearUpwind faceMDLimited Gauss linear 0.91;
//div((nuEff*dev(grad(U).T()))) Gauss linearUpwind faceMDLimited Gauss linear 0.85;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Do you have any suggestions ? Again many thanks for helping me so far! really appreciate it! Leon |
#23 |
Leon Eilders
had to be nNonOrthogonalCorrectors 2; Did the trick! Thanks for your help! |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| snappyHexMesh - layers in 3d pipe bifurcation | nihil | OpenFOAM Native Meshers: snappyHexMesh and Others | 13 | April 9, 2013 08:32 |
| SnappyHexMesh doesn't succeed in adding several layers | eti0123456789 | OpenFOAM Native Meshers: snappyHexMesh and Others | 5 | April 9, 2013 02:36 |
| Add Layers in snappyHexMesh | shchepan | OpenFOAM | 4 | June 17, 2012 14:55 |
| snappyHexMesh layers part | marine | OpenFOAM | 7 | April 27, 2010 07:09 |
| no boundary layers using snappyHexMesh | thorsten | OpenFOAM Native Meshers: snappyHexMesh and Others | 1 | October 22, 2009 06:01 |
