January 24, 2011, 06:48 |
.msh to Foam
Ashok
Rep Power: 15 |
I am new to OpenFoam. Please help me to convert .msh to Foam. In which directory I should keep the .msh file ? Which are the commands ? Waiting for your reply Thanks in advance... |
January 24, 2011, 07:25 |
Kurne
Rep Power: 15 |
Hello chitharenjan
I will explain you in detail.I want to covert fluent.msh file into OpenFOAM format.Make a directory of any name say Conversion.Now in Conversion directory copy the fluent.msh file.After this make three directories in Conversion name of system,constant and o as in all OpenFoam case files.After this copy the ControlDic,fvSchemes and fvSolutions from any tutorials file.Now go into Conversion directory by terminal and type fluentMeshToFoam fluent.msh.After this directly type paraFoam and you will see the mesh by using Wire frame in display panel. Enjoy Still if you face any problem then we will see.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne |
January 27, 2011, 01:53 |
paraView
Ashok
Rep Power: 15 |
Thanks Kurne,
But while entering paraFoam, instead of the wireframe model I am getting this message budha@budha-desktop:~/OpenFOAM/budha-1.7.1/run/tutorials/heatTransfer/buoyantSimpleFoam/hotRoom/Ashok$ paraFoam created temporary 'Ashok.OpenFOAM' /opt/openfoam171/bin/paraFoam: 142: paraview: not found Please help |
January 27, 2011, 04:57 |
Kurne
Rep Power: 15 |
Dear
Run paraFoam for other tutorials example if not then Check the cmake has installed properly.
January 27, 2011, 15:37 |
Rep Power: 15 |
It is even not necessary to use paraFoam, as long as you can open Paraview. After the simulation you run the command
touch myCase.foam and you open this file in Paraview. |
.msh, commands ?, directory ?, foam |
Display Modes | |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
