-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   a question about Massflow Calculation (http://www.cfd-online.com/Forums/openfoam/84414-question-about-massflow-calculation.html)
xck1986 January 28, 2011 09:18
Hi Foamusers,
I have use rhoSimpleFoam to simulate a valve. Now I have a question about the massflow calculation.
In openfoam WIKI I have found a function: http://openfoamwiki.net/index.php?ti...cts&oldid=9706
functions
massFlow
type patchMassFlow;
functionObjectLibs ( "libsimpleFunctionObjects.so" );
verbose true;
patches ( inlet outlet );
factor 19.7363;
What I am not clear is the factor 19.7363. For My case I have use factor=1.
But the massflow results I get is 30% smaller than the results simulated by another CFD software StarCCM+.
In OpenFOAM WIKI, it said:
factor A
factor with which the results should be multiplied before being written to disk/terminal. Used to account for symmetries etc (not used by all function objects) Depending on the type of the functionObject in this library these entries are used:
So can anyone tell me what means here account for symmetries?
For my model I have use half of the CAD valve model to run the simulation, so I have a symmetryplane. Do I need to set this factor bigger than 1?
Thanks a lot!
nimasam January 29, 2011 13:47
hi chenkai
let me describe my point with an example.
u have an axiymetric mesh (consider a tube, you choose a section of it) as ur cross section is a portion of the main cross section, ur mass will be a portion of mass flow too! so i guess im not sure at ALL! the factor equals (tube cross section/ chosen cross section)
