please help me with this gsl_integration error in hannes code
1 Attachment(s)
I would be very glad if someone could help me to solve the gsl_integration error that it occures during compiling Hannes repository. I just copied gsl header files to a folder inside integrator folder which is inside compositionpdf folder. The error is attached. Kind Regards, Farshad |
Hello Farshad,
please note that I used this code together with OF-1.5. I guess some things have changed in OF-1.7.1 and some modifications need to be done. I will try to port the code to OF-1.6-ext. I will let you know, if I made some progress. Regards, Hannes |
last modifications
1 Attachment(s)
Dear Hannes,
Thanks for sharing your useful code.I learned many things from that.I have modified make file for your library and only three small errors are left. I think the problem is with the order of puting arguments in Cuhre function. I have attached my last log after i deleted GSL cause i didnt need one dimension as you mentioned. Kind Regards, Farshad |
