February 7, 2011, 06:22 |
ansysToFoam
I have a problem. I want to use ansysToFoam, but the application doesn't run. After "Create Time" appears on the display nothing happens ... Can someone help me? Or some other hints to convert a mesh, produce with TurboGrid? case> ansysToFoam test.gtm /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.1-03e7e056c215 Exec : ansysToFoam test.gtm Date : Feb 07 2011 Time : 11:12:40 Host : pc6931 PID : 20129 Case : /... nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time |
February 7, 2011, 20:13 |
Scott
I'd try exporting as a .msh file in ASCII (search the forums to find out how) and use fluentMeshToFoam
.gtm is not supported as far as I am aware for ansysToFoam, it is for .inp I think. Feel free to correct me if I am wrong. Hope this helps! Scott |
February 7, 2011, 23:59 |
Kurne
Dear RalphS
Convert the mesh from TurboGrid to fluent mesh format which will give the mesh in .msh extension say fluent.msh. Copy this fluent.msh file in to your directory and use command fluent3DMeshToFoam fluent.msh. It will work.If still any problem then we will see it. Take Care
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne |
February 8, 2011, 08:45 |
Thanks,
I use ansys turbo grid 12.0. I didn't found out, how I am able to export to an Fluent .msh Mesh file. |
December 7, 2012, 16:31 |
Eric
I know this is an old thread but I am interested in this same conversion. I have a .gtm mesh that needs to be converted for use in openFoam. Anyone know how to get this done?
December 14, 2015, 08:34 |
Jack
Rep Power: 10 |
I'm also interested in this. I'm not sure how to convert turbo grid meshes into a format that can be converted to an openFoam readable mesh. If .msh is what I need how do I export a .msh file from turbo grid? Thanks!
December 14, 2015, 09:46 |
Olivier
hello,
Export in .msh (ascii format !). Import with fluent3DToFoam. If you can't export as a .msh, send to Fluent, then save as .cas (still in ascii !). You can import the .cas with fluent3DToFoam. regards, olivier |
December 15, 2015, 17:02 |
Jack
Rep Power: 10 |
Thanks for your response - I could only output files as .cgns and .gtm I have no idea how to open these again in turbo grid or to convert the mesh to something my solver (openFoam 2.3.1) can read... |
January 23, 2016, 20:44 |
Jack
Rep Power: 10 |
Can someone please offer any advice on this issue? Its driving me nuts!
[Commercial meshers] ansysToFoam >> which file should I use? | vitorspadeto | OpenFOAM Meshing & Mesh Conversion | 0 | May 8, 2014 23:23 |
[Commercial meshers] ansysToFoam stops | Mathias-TU | OpenFOAM Meshing & Mesh Conversion | 20 | October 17, 2013 04:01 |
