[stressAnalysis] a problem about boundary condition in stressanalysis |
February 8, 2011, 04:49 |
chenkai
Rep Power: 15 |
Hi everyone,
I want to simulate the torsion of a cylinder with OpenFOAM. (see the attached picture). But I don't know how to set the boundary condition of the outside for the cylinder, because the direction of the stress always changes. Does anyone have idea how to set this case? Is it possible to set the moment as boundary condition in OpenFOAM? Thanks a lot in advance. |
February 8, 2011, 11:28 |
MSR CHANDRA MURTHY
Rep Power: 17 |
It may be possible with GroovyBC.
February 10, 2011, 05:34 |
chenkai
Rep Power: 15 |
thanks a lot for your reply. But from the two tuturials of stressAnalysis in OpenFOAM, it seems that, in the time 0 folder, only the Displacement (D) boundary condition can be specified; which use the following boundary type: type tractionDisplacement traction uniform (0 0 0) //value for traction(stress) pressure uniform 0 value uniform (0 0 0) //value for Dispalcement But I want to define the traction uniform (0 0 0) not as a constant but as a variate. That means the vector depends on the position of the node. e.g.traction uniform ( 100*x/(x2+y2) 100*y/(x2+y2) 0 ). And when I use the GroovyBC, as far as I know, it seems like I can only specify a variate for the Displacement but not for the traction. Could please give some suggestion? Or is it possible to have a force or stress or moment as a boundary condition, which can be also defined in the 0 folder? Thanks again |
February 10, 2011, 08:42 |
#4 | |
MSR CHANDRA MURTHY
Rep Power: 17 |
have a nice day |
February 10, 2011, 11:59 |
#5 | |
chenkai
Rep Power: 15 |
Thanks a lot for your help. But it also seems like that a field musst be set in funkySetFields dictory. And I want to change the vector traction, which is not a field defined in time 0 folder, but a vector defined in the file of D(Displacement). So it's still a problem for me. But thanks again!!! |
February 11, 2011, 02:06 |
#6 | |
MSR CHANDRA MURTHY
Rep Power: 17 |
and solve it hope it will help the situation |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Pressure Boundary Condition Problem | rbjet | CFX | 3 | July 15, 2013 21:45 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
