How to find discretization schemes used in OF |
February 8, 2011, 20:44 |
Rep Power: 15 |
I've gotten a lot of help from this great group in the past, so hopefully someone can point me in the right direction for this:
I'm learning in class about equation discretizations for the fundamental PDEs required to CFD. We're looking at how different schemes can affect the soln stability and introduce phase errors, amplitude errors, etc. I'm trying to understand where these schemes are specified and, if not user-definable; what the default scheme is. The fvSolution file seems to define the solver settings for each variation, is this unique, or do commercial CFD packages actually solve each variable using a different algorithm? If fvSchemes involves PDE discretization, I've never heard of selecting a scheme based on each operation or variable. I've only studied "Scheme X applied to the momentum equation". Can anyone explain the difference, or is fvSchemes performing some alternate function? THANKS!! |
February 15, 2011, 11:07 |
Anton Kidess
Rep Power: 29 |
I'm pretty sure you can specify convergence criteria in every CFD package per variable. As for the solution algorithm, there might be less options but it should be possible to at least edit settings like the Multigrid cycle.
For fvSchemes, again there might be a bit more options as in other packages. But specifying which discretization to use for time stepping, gradient calculation and the discretization of the convective term should be fairly standard. |
Looking for SUBOFF model but i can't find it. | Heewon Lee | Main CFD Forum | 7 | March 5, 2017 13:36 |
Ways to find Mass transfer coefficient using CFD? | tuks_123 | CFX | 10 | April 15, 2011 11:20 |
Higher order schemes | RameshK | Main CFD Forum | 0 | July 15, 2010 22:35 |
What are the reasons for solution instability? | diaw | Main CFD Forum | 22 | September 25, 2005 01:14 |
Higher-order bounded convection schemes for pure advection with discontinuity | Anthony | Main CFD Forum | 3 | June 13, 1999 02:36 |
