-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Hydraulic jump (http://www.cfd-online.com/Forums/openfoam/84993-hydraulic-jump.html)
The King February 14, 2011 16:59
Hydraulic jump
I'm trying to simulate a hydraulic jump. Using VOF model, turbulent. Geometry is easy, slope of 5 degrees and a obstruction on the bottom. The water level before the opstruction is high, a little higher than the obstruction. Behind the obstruction, the water level is low and the velocity is much higher. But now hydraulic jump, the water level stays low.
If I do experiments, I see a hydraulic jump. In my setup, Fr>1 andRe >10000. I use wall functions in a 2D geometry.
Any idea wat I'm doing wrong? Is it possible to model hydraulic jumps in 2D or do I missed some physical understanding? Is there someone trying this before in OpenFoam? I have seen some fluent 2D calculations whit a hydraulic jump.
Thank you!
Arnout
santiagomarquezd February 14, 2011 23:12
If you can read spanish, here it's that you are looking for:
http://www.amcaonline.org.ar/ojs/ind...view/2826/2763
Regards.
The King February 15, 2011 16:54
Hi!
Thabo you. My case is different from the one in the article, I'm looking ar a jump behind a obstacle on the bottom. Let's see it as a river with a stone in it.
Going to try it with fluent now, wil keep Cfd online updated!
Any other hints are still welcome!!
Arnout
niravtm007 November 24, 2011 07:57
hii king can you please help me set up a geometry and can you tell me what results you obtaned using fluent, i'm also trying to simulate a hydraulic jump using fluent. do let me know what conditions you applied
mgdenno November 24, 2011 12:45
It should work in 2d. If you post your case I will take a look at it.
