blockMesh error with wedge bc
Old   February 15, 2011, 15:08
Default blockMesh error with wedge bc
George
GGerber is on a distinguished road
Hi OpenFoamers,
Can anyone tell me what the following error means:
--> FOAM FATAL ERROR:
wedge slices centre plane does not align with a coordinate plane by 1
I am trying to create a wedge geometry with main axis along the z-axis.
Thank you,
George
GGerber is offline   Reply With Quote
Old   February 15, 2011, 16:28
Paul Bryant
pbryant is on a distinguished road
I am new to this also, but it may be that the two planes of your wedge are not centered about one of the coordinate planes, in your case that would be either the xz plane or the yz plane, ie the two wedge planes should be on opposite sides of one coordinate plane.
pbryant is offline   Reply With Quote
Old   February 17, 2011, 14:50
George
Ok. Thanks I managed to get the mesh to build.
G
Old   February 25, 2022, 03:41
Quentin Chevalier
Quentin Chevalier is on a distinguished road
I'm having the same problem. I have a gmsh created mesh that I try to use as a wedge. It's aligned with x, but that used to work with with another wedge mesh I used.
Attached are the gmsh .geo file, the generated .msh file, as well as my full case. The nozzle.msh file must be placed inside the case file for ./Allrun to work.
I obtain the following error from createPatch :
--> FOAM FATAL ERROR: (openfoam-2112)
wedge back plane aligns with a coordinate plane.
    The wedge plane should make a small angle (~2.5deg) with the coordinate plane
    and the pair of wedge planes should be symmetric about the coordinate plane.
    Normal of wedge plane is (-1 0 0) , implied coordinate plane direction is (-1 0 0)
    From virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBuffers&)
    in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 112.
I also have a screen of the mesh attached. I'm pretty sure the large side plane closest to the viewer is the 'front' plane, and the point the pointer is on is off the y axis by 0.5 degree (it doesn't change anything to increase or decrease this number).
I would have expected the normal of this plane to be something like (0,-eps,1-eta), not (-1 0 0). What am I missing ?
Quentin Chevalier is offline   Reply With Quote
[blockMesh] Problems in creating a wedge type mesh Joscha OpenFOAM Meshing & Mesh Conversion 28 August 3, 2019 07:59
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Wall boundary is ignored when using wedge Wedge OpenFOAM 1 February 7, 2011 06:20
Fluid-Structure-Interaction on wedge mesh WiWo OpenFOAM 6 March 6, 2010 07:18
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
