March 17, 2011, 05:57 |
groovyBC OpenFoam 1.7
Dan
Rep Power: 15 |
Hi all I'm still a relative newb to Open Foam, so this might be a silly question but if I don't ask I will never learn.
I am running a simple Benchmark Flow over a cylinder using an example form Benchmark Computations of Laminar Flow Around a Cylinder; M. Sch ̈fera and S. Turekb On open Foam 1.7 in CAElinux 2010 The flow involves a parabolic inflow condition, so I decided to try groovyBC however I do not have the libraries I followed a link to the Wiki http://openfoamwiki.net/index.php/Contrib_groovyBC I have confirmed that i have bison however the download links at the botom of the page apear in HTML form, so It look like I will have to copy and paste the text of each individual file into a new text document. am I missing an obvious trick here, is there not a .tar folder or something I could download directly? Dandalf |
March 17, 2011, 06:45 |
Bernhard
Rep Power: 21 |
You should type svn checkout in your shell, followed by this url
March 17, 2011, 08:49 |
Dan
Rep Power: 15 |
Thanks Bernhard .. these things are so simple when you know how
March 17, 2011, 11:42 |
Dan
Rep Power: 15 |
I have managed to get the parabolic inlet profile working,
Although I only ran it over a small time period the drag and lift coefficients agree well with the benchmark solution. Unfortunately paraFoam seems to crash every time I try to load velocity and pressure values. I have attached a copy of the system for anyone that is interested. Dandalf |
March 17, 2011, 12:11 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://openfoamwiki.net/index.php/Co...to_controlDict The interesting part starts after "If you are experiencing problems with paraFoam" |
March 17, 2011, 12:44 |
Dan
Rep Power: 15 |
Hi gschaider
I had spotted that however it didn't seem to make any difference. |
March 18, 2011, 05:01 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Yes it does. If you use such stuff: COPY PASTE IT. That way the capital letters are right and you're not wasting my time. And if you had actually looked at the error message from paraview ("could not load libOpenFoam.so: cannot open shared object file: No such file or directory") or posted it here it would have been a matter of minutes (apart from having to guess your OF-version and the paraview-version)
March 18, 2011, 05:19 |
Dan
Rep Power: 15 |
Thanks gschaider, I guess my typing gets sloppy towards the end of a long day.
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0 | alberto | OpenFOAM | 12 | July 28, 2010 11:59 |
