Exception en point flottant
Hello
I realize diffrents calcul with OpenFoam on hulll of ship and I have a problem of "Exception en point flottant (core dumped)". Have you got a solution? Thanks a lot |
Which version of OF and which solver are you using ?
I need more details about the flow and the properties of you mesh to help you. Will help if you can post a checkMesh and your 0 and System Folder |
Also, please give the error messages and some output of the solver.
At least, if they are in French too I cannot help you. |
Hi Foameres,
I need a help. I'a running a turbDymFoam on OF 1.5 and the simulation stops because of Courant Number max: 141.84163. Courant Number mean: 0.0032354185 max: 141.84163 velocity magnitude: 86683250 deltaT = 9.8152931e-09 GGI pair (GGI_INT, GGI_EXT) : 3.4097586e+09 3.3529672e+09 Diff = -56791406 or 1.665555 % Time = 4.68963e-05 Initializing the GGI interpolator between master/shadow patches: GGI_INT/GGI_EXT Evaluation of GGI weighting factors: Largest slave weighting factor correction : 0.00022623882 average: 0.00014960287 Largest master weighting factor correction: 4.4408921e-16 average: 7.3303187e-17 Exception en point flottant regards, Pla. |
