segmentation error
Hello everybody,
I want to correct a boundary condition of a variable called “nHatfv” by means of working with “nHapt” in these lines: surfaceVectorField::GeometricBoundaryField& nHatb = nHatfv.boundaryField(); const fvBoundaryMesh& boundary = mesh.boundary(); forAll(boundary, patchi) { fvsPatchVectorField& nHatp = nHatb[patchi]; vectorField nf = boundary[patchi].nf(); scalarField a12 = nHatp & nf; scalarField b2(nHatp.size()); forAll(b2,facei) { b2[facei] = Foam::cos(Foam::acos(a12[facei])); } nHatp /=b2*a12; } The solver compiles Ok without errors, but when I want to run my tutorial, I have the folllowing error: #0 Foam::errorprintStack(Foam::Ostream&) in "/home/isabel/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/isabel/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb807a400] #3 main in "/home/isabel/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/informe24" #4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #5 _start at /build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 Segmentation error and I saw that the error dissapears if I supress these lines: forAll(b2,facei) { b2[facei] = Foam::cos(Foam::acos(a12[facei])-theta[facei]); } But I need these lines. What can I do? |
Let me guess - do you have any empty patches?
May be, in the first lime I equal “nHatb = nHatfv.boundaryField()”, but I did not defined nHatfv in my “createFields.H”.
Is this the problem? |
