-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Curvature of the interface using interFoam (http://www.cfd-online.com/Forums/openfoam/85562-curvature-interface-using-interfoam.html)
Andrea_85 March 1, 2011 13:16
2 Attachment(s)
Hi all,
I am using interFoam to simulate multiphase flow in different geometries and I tried to write a little piece of code (writeCurvature.C that i call as a post processing) to calculate the curvature of the interface following the same method that openFoam normally use in the VOF method. (the calculations that i have done are identical to those in interfaceProperties.C). The problem is that I get strange result. I expected to find high values near the interface and values close to zero in the bulk but it is not!
i attached 2 jpg. one is the colour plot of alpha1 and the other one is the colour plot of the curvature that i got.
Any suggestion?
thanks
andrea
Andrea_85 March 2, 2011 04:19
someone who has any idea why I find this curvature?
These are the calculations I've done:
reading alpha1 first
then
// now calc the gradients
        volVectorField gradAlpha1 = fvc::grad(alpha1);
        Info<< "Writing gradAlpha1 to " << gradAlpha1.name() << " in "
            << runTime.timeName() << endl;
        gradAlpha1.write();
        // Interpolated face-gradient of alpha
        surfaceVectorField gradAlphaf = fvc::interpolate(gradAlpha1);
        dimensionedScalar deltaN_ =  1e-8/pow(average(alpha1.mesh().V()), 1.0/3.0);
        // Face unit interface normal
        surfaceVectorField nHatfv = gradAlphaf/(mag(gradAlphaf) + deltaN_);
        // Face unit interface normal flux
        const surfaceVectorField& Sf = mesh.Sf();
        surfaceScalarField nHatf_ = nHatfv & Sf;
        volScalarField curvature
        IOobject
          "Curvature",
          runTime.timeName(),
          mesh,
          IOobject::NO_READ,
          IOobject::AUTO_WRITE
        -fvc::div(nHatf_)
The thing that I can not understand is if I'm doing something wrong or if it is normal to find such values
thanks
andrea
