Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
neighbour cell bug
Old   May 20, 2015, 03:33
Question neighbour cell bug
Elisa Lafforgue
Elisa-L is on a distinguished road
When I start a blockMesh command for my Wind tunnel modelisation, I have always the same error, even if I remake the whole code I still have this error on the same cell, whatever I change in the code ...
This error always appears:
--> FOAM FATAL ERROR: face 24 in patch 0 does not have neighbour cell face: 4(27 218 129 28) From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.FOAM aborting
However, the checkMesh command says my mesh is ok...
So I wonder if this is a bug or if I am just to stupid to make a right code ... Could you help me please?
ps: I use OpenFoam 2.1.1
Elisa L.
Elisa-L is offline   Reply With Quote
Old   May 21, 2015, 04:24
Elisa Lafforgue
Hey,
As I am completely lost now, I will explain the détails of my problems, if anyone could help I'd be grateful because as it is needed for my job I really need help!
My problem:
I wrote a code corresponding to a simple Wind tunnel at the beggining and I slowly added geometrical caracteristics like spline and arc. My Wind tunnel worked. And now, I have to add some shutters at the inlet. So, the problems began: I had to implement the shutters in the actual inlet, so to do it the simplest way, I cut the inlet in two parts, in some way I reduced the previous "inlet" and added, before it, the part which contains the shutters. Now that I had created the points for the shutters, I had to create the blocks (the parts between the shutters) and the "walls" of all the shutters. I created it the simplest way again: first I made simple blocks and big simple faces, then it didn't work so I divided, step by step, the part with the shutters to have the same "cut lines" everywhere in this part...
Now the real problem is: at the beggining I had trouble with a face, that didn't have neighbours... as shown below:
So I divided some parts... And I had the same exact message!it was about the same face again, the first face in the list of shutter faces...
And now that I had changed all the code and even divided some parts in triangular (and so it is for the first face of the shutter faces)... I have the same message! What did I do wrong? Please help me! Even my professor can't tell!
I attach my code for your consideration, some parts are in french but I don't think it is really annoying as it is just for some indications (shutter = registre).
block mesh, bug, cell, face, mesh
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
Problem/ bug in mesh.cellCells() ?? daZigeiner OpenFOAM Bugs 2 May 18, 2015 15:54
interFoam running blowing up sandy13 OpenFOAM Running, Solving & CFD 2 May 5, 2015 07:16
monitoring cell Jane Siemens 2 March 4, 2004 21:01
cell to cell relation CMB Siemens 1 December 4, 2003 04:05
