Gas Turbine combustor inlet boundary condtions |
March 3, 2011, 10:46 |
José Rodrigues
Im trying to simulate a gas turbine combustor for which I know inlet conditions (massflow, pressure, temperature) and I want to evaluate efficiency of the combustor based on the outlet conditions. I have experienced that OF blows up whenever I specify at the inlet (fixedValue BC) either: a) temperature pressure and velocity (T p U - fixedValue) b) pressure and massflow (p phi - fixedValue) c) pressure and velocity (p U - fixedValue) The other quantities are set to zeroGradient (note for velocity also used pressureInletVelocity). FYI, im using reactingFoam which uses PISO solver for momentum equations. This is a simulation for my master thesis, so I really need your precious help. Any suggestions? Thx |
March 3, 2011, 15:48 |
Niels Nielsen
Rep Power: 27 |
Hi Jose
look here for inspiration LINK TO THESIS This is my master thesis, keep in mind we where very new to both CFD and OF moreso at the time. Also its using OF 1.4.1 but you should be able to get some inspiration.
Linnemann PS. I do not do personal support, so please post in the forums. |
May 7, 2012, 01:17 |
#3 | |
could you please email your thesis for me? your link dose not work anymore Email: Reza.khodadadi@modares.ac.ir and Could you please tell me, if your code, is for dynamic state of combustor? And do you have ATEC code or any code that maybe I can use to simulate this model? many regards khodadadi. |
May 18, 2012, 07:13 |
Helpp
I have been trying to use ANSYS FLUENT Software to simulate cold flow analysis inside a combustion chamber. But I am having difficulties. It shows reverse flow when I run the calculation. My geometry is in 2D-Axisymmetrical. Also I have taken a swirl facter of 0.7 using K-Epsilon RNG turbulence method.
Inlet condition: Velocity- 1m/s, Air at 600K Pressure Outlet - Gauge pressure=0 Is the reverse flow because I have included the swirl in the flow? Or is it because my domain is small? I would really appreciate if you can help me figure out the problem. Thanks in advance. |
boundary conditions, combustion, gas turbine |
3D Gas Turbine Combustor | Ehsan Alborzi | FLUENT | 1 | May 18, 2012 05:17 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
Gas turbine load problem | hashimbukhari | Main CFD Forum | 2 | July 24, 2010 03:48 |
flow in gas turbine | Abdul Hafid | Main CFD Forum | 1 | September 14, 1998 09:39 |
