[Thank you for help] How comes this modified lapalacianFoam can not be 'wmake'?
Hi, guys
There is a case that I am trying to add a time dependent term in laplacianFoam solver, which is theoretically easy, but when I typed in "wmake" after modified create.H, write.H, and cureLaplacianFoam.C, error occurred w/o detail. my code in cureLaplacianFoam.C, changing from the original laplacianFoam.C: //add line here// fvScalarMatrix alphadot ( fvm::(a1*exp(-d1/R/T)+a2*exp(-d2/R/T)*alpha^m)*(1-alpha)^n ); alphadot.solve(); //addition end// for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { solve ( fvm::ddt(T) - fvm::laplacian(KRhoC, T)- HC*alphadot ); //add line here// solve ( fvm::ddt(alpha) - alphadot ); //addition end// } "alpha" is an added field, to be calculated by linear integration from "alphadot", which is a function of temperature and the last values of "alpha" as you see it. and when I compiled it with wmake, error occurred as (you can just see the highlight sentence in the end of this bunch): Making dependency list for source file cureLaplacianFoam.C SOURCE=cureLaplacianFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/cureLaplacianFoam.o cureLaplacianFoam.C: In function ‘int main(int, char**)’: cureLaplacianFoam.C:58: error: expected unqualified-id before ‘(’ token In file included from /opt/openfoam171/src/OpenFOAM/lnInclude/doubleFloat.H:30, from /opt/openfoam171/src/OpenFOAM/lnInclude/floatScalar.H:38, from /opt/openfoam171/src/OpenFOAM/lnInclude/scalar.H:39, from /opt/openfoam171/src/OpenFOAM/lnInclude/IOstream.H:49, from /opt/openfoam171/src/OpenFOAM/lnInclude/Ostream.H:39, from /opt/openfoam171/src/OpenFOAM/lnInclude/OSstream.H:40, from /opt/openfoam171/src/OpenFOAM/lnInclude/messageStream.H:219, from /opt/openfoam171/src/OpenFOAM/lnInclude/error.H:51, from /opt/openfoam171/src/OpenFOAM/lnInclude/UListI.H:26, from /opt/openfoam171/src/OpenFOAM/lnInclude/UList.H:349, from /opt/openfoam171/src/OpenFOAM/lnInclude/List.H:43, from /opt/openfoam171/src/OpenFOAM/lnInclude/labelList.H:36, from /opt/openfoam171/src/OpenFOAM/lnInclude/Pstream.H:43, from /opt/openfoam171/src/OpenFOAM/lnInclude/OPstream.H:35, from /opt/openfoam171/src/OpenFOAM/lnInclude/parRun.H:35, from /opt/openfoam171/src/finiteVolume/lnInclude/fvCFD.H:4, from cureLaplacianFoam.C:32: /opt/openfoam171/src/OpenFOAM/lnInclude/products.H: At global scope: /opt/openfoam171/src/OpenFOAM/lnInclude/products.H: In instantiation of ‘Foam::crossProduct<double, double>’: cureLaplacianFoam.C:58: instantiated from here /opt/openfoam171/src/OpenFOAM/lnInclude/products.H:85: error: no type named ‘type’ in ‘class Foam::typeOfRank<double, -0x00000000000000001>’ cureLaplacianFoam.C: In function ‘int main(int, char**)’: cureLaplacianFoam.C:58: error: no match for ‘operator^’ in ‘Foam::operator+(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = double, Type2 = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >*)(& Foam::operator*(const Foam::tmp<Foam::GeometricField<double, PatchField, GeoMesh> >&, const Foam::GeometricField<double, PatchField, GeoMesh>&) [with PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)((const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*)(& alpha)))))))) ^ m’ /opt/openfoam171/src/OpenFOAM/lnInclude/dimensionSet.H:279: note: candidates are: Foam::dimensionSet Foam::operator^(const Foam::dimensionSet&, const Foam::dimensionSet&) /usr/include/c++/4.4/bits/ios_base.h:170: note: std::_Ios_Iostate std::operator^(std::_Ios_Iostate, std::_Ios_Iostate) /usr/include/c++/4.4/bits/ios_base.h:132: note: std::_Ios_Openmode std::operator^(std::_Ios_Openmode, std::_Ios_Openmode) /usr/include/c++/4.4/bits/ios_base.h:92: note: std::_Ios_Fmtflags std::operator^(std::_Ios_Fmtflags, std::_Ios_Fmtflags) cureLaplacianFoam.C:58: warning: suggest parentheses around arithmetic in operand of ‘^’ /opt/openfoam171/src/finiteVolume/lnInclude/readSIMPLEControls.H:6: warning: unused variable ‘momentumPredictor’ /opt/openfoam171/src/finiteVolume/lnInclude/readSIMPLEControls.H:9: warning: unused variable ‘transonic’ make: *** [Make/linuxGccDPOpt/cureLaplacianFoam.o] Error 1 I dont know what happened to .o file, wondering if there is any problem in the solver, cureLaplacianFoam.C . Thank you for help, I really appreciate your time! -Merlin- |
Hi Merlin!
Your code can't compile. Indeed, your first declaration is a non-sense: alphadot is not a matrix. In fact it is just a field that depends on the other variables. Code:
volScalarField alphadot = (a1*exp(-d1/R/T)+a2*exp(-d2/R/T)*alpha^m)*(1-alpha)^n; You can even optimise the resolution using fvm::Sp() to deal with the source term of your last equation... @++ Cyp |
Appreciate your help pretty much. I think it makes a lot of sense to me. But... After changing my code to those you provide, the same error occurred. I think I should paste createFields.H here: Info<< "Reading field T\n" << endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field alpha\n" << endl; volScalarField alpha ( IOobject ( "alpha", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading transportProperties\n" << endl; IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); Info<< "Reading KRhoC\n" << endl; dimensionedScalar KRhoC ( transportProperties.lookup("KRhoC") ); Info<< "Reading HC\n" << endl; dimensionedScalar HC ( transportProperties.lookup("HC") ); Info<< "Reading cureProperties\n" << endl; IOdictionary cureProperties ( IOobject ( "cureProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); Info<< "Reading a1\n" << endl; dimensionedScalar a1 ( cureProperties.lookup("a1") ); Info<< "Reading a2\n" << endl; dimensionedScalar a2 ( cureProperties.lookup("a2") ); Info<< "Reading d1\n" << endl; dimensionedScalar d1 ( cureProperties.lookup("d1") ); Info<< "Reading d2\n" << endl; dimensionedScalar d2 ( cureProperties.lookup("d2") ); Info<< "Reading R\n" << endl; dimensionedScalar R ( cureProperties.lookup("R") ); Info<< "Reading m\n" << endl; dimensionedScalar m ( cureProperties.lookup("m") ); Info<< "Reading n\n" << endl; dimensionedScalar n ( cureProperties.lookup("n") ); actually, I cant find anything special here....I stored KRhoC and HC in transportproperties, and other parameters in cureProperties. Sorry for bothering you and other guys again. |
Hi!
Your last error comes from the power in your alphadot expression : in c++ a^b is pow(a,b). Now, your code should compile perfectly. Best, Cyp |
You are the MAN !! :):):) It has been complied smoothly. Grateful for your instruction and learnt a lot from your suggestion! Merlin- Truly |
