okay, the Womersley solution validation
nobody answers my last post. So I think I need to ask my question in another way.
I think people in this community already did validation against the theoritical solution a lot before. My question is this: I have a velocity inlet V(t)=cos(t), I use icoFoam as the solver, (as in the cavity tutorial), but I need to change the BC from constant inlet velocity to varying bc. How to do it then? One answer I found online is oscillatingFixedValue: http://openfoamwiki.net/index.php/Ma...tingFixedValue But after checking the result, i do not think it is pure oscilating, instead, it is a function of sine together with a steady positive flow rate. like http://openfoamwiki.net/images/math/...0bab4045ce.png if I delete 1 from the above formular, there is simly no flow then. I want a flow with back flow at some time steps. Anybody knows what is wrong? or any other function instead of oscillatingFixedValue? Thanks |
Why are you applying this BC in the cavity, and not in pipe, or duct flow, as one would expect? What are your outflow boundary conditions?
it is a 3d pipe, the outlet BC is pressure is zero.
