June 17, 2011, 01:20 |
need information in OpenFoam
Hello Guys,
Generally, the initial values need to be given to the BCs of Pressure and Velocity. Now the problem is: I have used in my problem the Velocity inlet & Pressure Outlet BC. Is there any possibility of putting the Pressure Outlet condition in OpenFoam as implicit and that values I want to be computed from the solution of earlier nodal points? The velocity BC at outlet is zeroGradient. As per other BCs are concerned, for the inlet pressure BC I am defining as zeroGradient since I have given Inlet velocity BC it's value. |
Compiling OpenFOAM on hpc-fe.gbar.dtu.dk | kaergaard | OpenFOAM Installation | 1 | June 16, 2011 01:33 |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 05:51 |
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev | OFU | OpenFOAM Meshing & Mesh Conversion | 0 | June 16, 2010 04:36 |
2009 OpenFOAM Summer School in Zagreb, Croatia | hjasak | OpenFOAM Announcements from Other Sources | 0 | March 27, 2009 12:08 |
information about moving mesh in openfoam | sambatra | OpenFOAM Running, Solving & CFD | 2 | March 26, 2009 11:16 |
