-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Always crash when solve a C-D nozzle flow field using rhoCentralFoam (http://www.cfd-online.com/Forums/openfoam/85853-always-crash-when-solve-c-d-nozzle-flow-field-using-rhocentralfoam.html)
hawklion March 8, 2011 11:48
2 Attachment(s)
dear all:
I have used the rhocentralFoam in OpenFoam to solve an CD nozzle with subsonic inlet and supersonic outlet.
But there is always an error after serval iteration steps even if I have tried varied boundary conditions for the case (you can find them in the notes of the P、U、T files in the 0 folder). Can anyone give me some advice?
thanks!
hawklion March 8, 2011 20:01
source code"0"
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1013250;
boundaryField
symmetry.5
type symmetryPlane;
wall.2
type zeroGradient;
/* pressure_inlet.3
type totalPressure;
p0 uniform 1.01325e+06;//:p_in
U U;
phi phi;
rho none;
psi none;
gamma 1.4;
value uniform 1.01325e+06;
pressure_outlet.4
type waveTransmissive;
value uniform 100; //important for correct I/O
field p; //the name of the field that we are working on
gamma 1.4; //the ratio of specific heats
phi phi; //the name of the volumetric flux field (or if you use the mass flux phi, it will be divided by rho)
rho rho; //the name of the density field
psi psi; //the name of the field that is the deriv. of density with respect to pressure
lInf 1; //a measure of how far away the far-field condition should be
fieldInf 100; //the far-field value to be applied to p
pressure_inlet.3
type fixedValue;
pressure_outlet.4
type zeroGradient;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 2000;
boundaryField
symmetry.5
type symmetryPlane;
wall.2
type zeroGradient;
pressure_outlet.4
type zeroGradient;
pressure_inlet.3
type fixedValue;
value uniform 2000;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (30 0 0);
boundaryField
symmetry.5
type symmetryPlane;
wall.2
type fixedValue;
value uniform (0 0 0);
pressure_outlet.4
type zeroGradient;
pressure_inlet.3
type pressureInletVelocity;
// type pressureDirectedInletOutletVelocity;
value uniform (30 0 0);
frontAndBackPlanes
type empty;
hawklion March 8, 2011 20:03
source code"constant"
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>;
mixture air 1 28.9 717.5 0 1.82e-05 0.73;
//thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
//mixture air 1 28.9 1007 0 1.84e-05 0.7;
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType laminar;
source code"system"
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application rhoCentralFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 100;
deltaT 1e-4;
writeControl adjustableRunTime;
writeInterval 1e-1;
cycleWrite 0;
writeFormat ascii;
writePrecision 15;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
adjustTimeStep yes;
maxCo 0.2;
maxDeltaT 1;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
fluxScheme Kurganov;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(tauMC) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
reconstruct(rho) MUSCL;
reconstruct(U) MUSCLV;
reconstruct(T) MUSCL;
snGradSchemes
default corrected;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
rho
solver diagonal;
rhoU
solver diagonal;
rhoE
solver diagonal;
U
solver smoothSolver;
smoother GaussSeidel;
nSweeps 2;
tolerance 1e-09;
relTol 0.01;
e
nSweeps 2;
tolerance 1e-10 relTol 0;
