-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   potentialFoam error (http://www.cfd-online.com/Forums/openfoam/85936-potentialfoam-error.html)
djstoneage March 9, 2011 23:50
potentialFoam error
Hi all im trying to run an atmospheric wind study case on and offshore platform. my control volume is a cylindrical domain, when ever i run potentialFoam is jsut return me an error as below :-
Please advice
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  1.6.x                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
Build  : 1.6.x
Exec  : potentialFoam
Date  : Mar 10 2011
Time  : 11:45:08
Host  : localhost.localdomain
PID    : 4966
Case  : /home/clee/Desktop/QU1
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading field p
Reading field U
Calculating potential flow
#0  Foam::error::printStack(Foam::Ostream&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  __restore_rt at sigaction.c:0
#3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4  Foam::DICPreconditioner::DICPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#5  Foam::lduMatrix::preconditioner::addsymMatrixConstructorToTable<Foam::DICPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#6  Foam::lduMatrix::preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#7  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#8  Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#9  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#10  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#11  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#12  main in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/potentialFoam"
#13  __libc_start_main in "/lib64/libc.so.6"
#14  Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/potentialFoam"
Floating point exception
prasanth October 19, 2011 13:45
Please advice
Build  : 1.6.x
Date  : Mar 10 2011
Time  : 11:45:08
PID    : 4966
nProcs : 1
Create time
Reading field p
Reading field U
Hello
I am also facing with same issue. Did you able to manage it? If so, Please reply me how you manage to run the case
laurent98 November 9, 2011 19:40
a beginner error?
hi to all,
i am very beginner on OF 2.0.1, on ubuntu 11; and when i try to run tutorial case of potentialFoam i have this message;
--> FOAM FATAL IO ERROR:
Loading a shared library using case-supplied code is not enabled by default
because of security issues. If you trust the code you can enable this
facility be adding to the InfoSwitches setting in the system controlDict:
allowSystemOperations 1
The system controlDict is either
~/.OpenFOAM/$WM_PROJECT_VERSION/controlDict
or
$WM_PROJECT_DIR/etc/controlDict
i try to add this line in controlDict, it does the same message
thanks specialiste for helping ... LL
