Convergence check on forces
Old   March 13, 2011, 16:43
Default Convergence check on forces
Andrea Pasquali
andrea.pasquali is on a distinguished road
I'm trying to add the convergence check on forces function following the residuals convergence check in simpleFoam.
For example, for the forces pressure, I added those lines:
scalar eqnResidualFF = 1, maxResidualFF = 0;
eqnResidualFF = solve
fm.first().first() += sum(fN)
).initialResidual();
maxResidualFF = max(eqnResidualFF, maxResidualFF);
After compilation I got the error:
error: invalid use of void expression
What I'm wronging? I think it does not like the expression:
Could anyone help me to go ahead?
Thanks
Andrea
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   March 16, 2011, 05:24
Andrea Pasquali
I solved my problems and I did the new lib to check the error on the forces / moments.
At now I calculate the increment between it i and it i-1:
err = || (force)[i] - (forces)[i-1] ||
I attached the plots for increment, residuals and force.
I'd like to stop the calculation when the force becomes more or less constant (2000-3000 its) without waiting for residuals convergence check (because it is possible my Ux Uy Uz residuals don't decrease under the convergence declared in fvSolution).
I hoped to do that checking the increment but as you can see it is very dispersive.
Is it possible to do what I want to do?
Thanks in advance for any help and suggestion
Andrea
Andrea Pasquali
Forces in V1.6 terrybarnaby OpenFOAM Post-Processing 72 September 2, 2015 16:49
Forces calulated through pressure LVDH OpenFOAM Post-Processing 2 February 26, 2010 03:15
Calculate forces without hydrostatic pressure geir_oye FLUENT 4 November 12, 2009 09:12
changes to forces in 1.6 linnemann OpenFOAM Running, Solving & CFD 0 July 30, 2009 08:49
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
