Home > Forums > OpenFOAM
atmospheric wind study
Old   March 14, 2011, 03:50
Default atmospheric wind study
chyn wey lee
djstoneage is on a distinguished road
Hi all i am tryng to model an atmospheric wind over an off shore platform with a K-Epsilon model. when i run simpleFoam im getting a pointstack error as below :_
[clee@localhost QU]$ simpleFoam
|  \\    /   O peration     | Version:  1.6.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 1.6.x
Exec   : simpleFoam
Date   : Mar 14 2011
Time   : 15:38:01
Host   : localhost.localdomain
PID    : 6519
Case   : /home/clee/Desktop/QU
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
--> Upgrading k to employ run-time selectable wall functions
    Backup original k to k.old
    Writing updated k
--> Upgrading epsilon to employ run-time selectable wall functions
    Backup original epsilon to epsilon.old
    Writing updated epsilon
--> Creating nut to employ run-time selectable wall functions
    Writing new nut
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.05163843541, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.05450915783, No Iterations 3
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.03639899326, No Iterations 2
#0  Foam::error::printStack(Foam::Ostream&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  __restore_rt at sigaction.c:0
#3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4  Foam::DICPreconditioner::DICPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#5  Foam::lduMatrix::preconditioner::addsymMatrixConstructorToTable<Foam::DICPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#6  Foam::lduMatrix::preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#7  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#8  Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#9  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#10  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#11  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#12  main in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam"
#13  __libc_start_main in "/lib64/libc.so.6"
#14  Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/clee/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam"
Floating point exception
anyone has got any idea on whats the problem
djstoneage is offline   Reply With Quote
Old   March 14, 2011, 21:23
chyn wey lee
noone has an asnwer to this??
Old   March 15, 2011, 09:00
Goncalo Pedro
gonpe is on a distinguished road
How are you specifying your boundary conditions?
Goncalo
gonpe is offline   Reply With Quote
Old   March 15, 2011, 22:49
chyn wey lee
currently my boundry condition is a cylindrical control volume. ive specified the top and the sides to be an inlet the bottom of the control volume which represent the sea and my geometry(offshore plateform) to be walls.
i am trying to run a simple kepsilon turbulence model.
i need help in setting up the case, i am trying to replicate a CFX run to validate results.
Old   March 16, 2011, 04:34
Matthias Voß
mvoss is on a distinguished road
no offense but even in CFX:
-if its a cylinder and you have one wall and 2 inlets where shall the flow go too?
-the platform is @ the axis of the cylinder?
mvoss is offline   Reply With Quote
Old   March 16, 2011, 05:28
chyn wey lee
in cfx i specified it as an opening. i am trying to figure out how to replicate that. does the inletOutlet type the same as opening type in CFX?
Old   March 16, 2011, 06:04
Matthias Voß
Since i know that from CFX, you can cut the entire domain in half, depending on the wind dir. and specify one half as inlet and the other half as a inletOutlet (no backflow) with 0Pa rel.Pressure and the top as zeroGradient for the vel. and a desired pressure level for p.
If you really have an pressure/velocity-atmospheric profile you should think about using grovvybc to set everything depending on the height of your domain.
Old   March 17, 2011, 22:46
chyn wey lee
i am trying to setup this boundary condition on my domain but cant seem to figure out a way to define it.
this is a CEL script from CFX
AirDensity = 1 [atm] / (287.06 [J kg^-1 C^-1] *AirTemperature)
AirTemperature = 10[C]
ak=0.41[]
cmu=0.090000004[]
cmuhalf=cmu^0.5
dir=0[]
dira=dir*pi180
ed1=(ustarnew^3)/(ak*(zabs-zref))
eps=30.0 *z0
pi180=pi/180
speed =(ustarnew*loge((zabs-zref)/z0)/ak)*step((z-z0)/1[m])
te1=ustarnew^2)/cmuhalf
thetaa=dira+(pi/2.0)
u1=speed*cos(thetaa)
uref=2[m s^-1]
ustarnew=al*uref/loge((zuref-zref)/z0)
v1=-speed*sin(theetaa)
w1=0.0[ms^-1]
z0=0.001[m]
zabs=abs(z+1E-007[m])
zref=0[m]
zuref=10[m]
anyone knows how to do this??
Old   March 18, 2011, 04:12
Matthias Voß
Did you took a look at atmBoundaryLayerInletVelocity?
Old   March 18, 2011, 04:49
chyn wey lee
i just found out about its existance it openFoam1.7.1 i am installing it right now. will try it out
Old   March 21, 2011, 01:16
chyn wey lee
i am trying to use theatmBoundaryLayerInletEpsilon boundary condition but when i run potentialFoam it says its an invalid patch type.
DOMAIN
type atmBoundaryLayerInletEpsilon;
Ustar $Ustar;
z $zDirection;
z0 $z0;
value $internalField;
zGround $zGround;
this is how i've set my boundary condition.
Old   March 21, 2011, 02:13
chyn wey lee
when i run simpleFoam this is what i am getting
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 1.7.1-03e7e056c215
Exec   : simpleFoam
Date   : Mar 21 2011
Time   : 14:10:17
PID    : 21308
Case   : /home/clee/Desktop/DPQU
nProcs : 1
Create time
Reading field p
Reading field U
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
Starting time loop
Time = 1
^TsmoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.09952992287, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.09000813227, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.03000555398, No Iterations 2
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 5.42432e+06
Specified mass inflow   : 1.37928e+06
Specified mass outflow  : 1.37925e+06
Adjustable mass outflow : 0
    From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
    in file cfdTools/general/adjustPhi/adjustPhi.C at line 115.
FOAM exiting
Old   March 21, 2011, 07:25
inginer's Avatar
Ovidiu Michiu
inginer is on a distinguished road
hello,
try to take a look in the tutorial of simpleWindFoam. you can find it in tutorials/incompresible/simpleWindFoam. there you have a case, which maybe close to your problem.
Best,
Ovidiu
inginer is offline   Reply With Quote
Old   March 23, 2011, 00:48
chyn wey lee
I followed the tutorial but importing in myown mesh from icem. it runs perfectly without turbulence, but when i turn on turbulence it crashed out after 2 iterations as below : - please advice on the following issues
apreciate any help
thank yo
Exec   : simpleFoam -parallel
Date   : Mar 23 2011
Time   : 12:14:23
PID    : 22423
Case   : /home/clee/Desktop/DPQU4
nProcs : 6
Slaves :
5
localhost.localdomain.22424
localhost.localdomain.22425
localhost.localdomain.22426
localhost.localdomain.22427
localhost.localdomain.22428
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
Create time
Reading field p
Reading field U
--> FOAM Warning :
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/quy/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/Field.C at line 262
    Reading "/home/clee/Desktop/DPQU4/processor0/0/nut::boundaryField::SEA" from line 31 to line 34
    expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
--> FOAM Warning :
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.11;
    Prt             1;
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0555723564877, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0550617478002, No Iterations 3
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0505116027098, No Iterations 2
smoothSolver:  Solving for p, Initial residual = 1, Final residual = 0.00998051548345, No Iterations 276
smoothSolver:  Solving for p, Initial residual = 0.110253383451, Final residual = 0.002106445285, No Iterations 300
time step continuity errors : sum local = 3.83276734343, global = -2.75858375028, cumulative = -2.75858375028
smoothSolver:  Solving for epsilon, Initial residual = 0.998076065936, Final residual = 0.0531743869439, No Iterations 4
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0312753766608, No Iterations 2
bounding k, min: 0 max: 2.7152548344e-05 average: 1.38834995478e-07
ExecutionTime = 217.58 s  ClockTime = 221 s
Time = 2
smoothSolver:  Solving for Ux, Initial residual = 0.497202681096, Final residual = 0.0275293576353, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 0.596221211389, Final residual = 0.0324851173556, No Iterations 3
smoothSolver:  Solving for Uz, Initial residual = 0.605757042665, Final residual = 0.0292697272504, No Iterations 3
smoothSolver:  Solving for p, Initial residual = 0.999999994462, Final residual = 0.0269541218382, No Iterations 300
smoothSolver:  Solving for p, Initial residual = 0.0128499408047, Final residual = 0.000832027351103, No Iterations 300
time step continuity errors : sum local = 16.0815980332, global = -3.02734777888, cumulative = -5.78593152916
[0] #0  Foam::error::printStack(Foam::Ostream&)[5] #0  Foam::error::printStack(Foam::Ostream&)[3] #0  Foam::error::printStack(Foam::Ostream&)[2] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #1  Foam::sigFpe::sigFpeHandler(int)[4] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #1  Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[5] #1  Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #1  Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[4] #1  Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #2   in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[5] #2   in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #2  __restore_rt in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[4] #2   in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #2   at sigaction.c:0
[0] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)__restore_rt__restore_rt in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)__restore_rt__restore_rt at sigaction.c:0
[5] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[0] #5  Foam::incompressible::RASModels::kEpsilon::correct() at sigaction.c:0
[4] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[5] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at sigaction.c:0
[3] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at sigaction.c:0
[2] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[4] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[0] #6   in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[4] #5  Foam::incompressible::RASModels::kEpsilon::correct() in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[5] #5  Foam::incompressible::RASModels::kEpsilon::correct() in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[4] #6   in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[5] #6  ?? in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[2] #5  Foam::incompressible::RASModels::kEpsilon::correct() in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[3] #5  Foam::incompressible::RASModels::kEpsilon::correct() in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/simpleFoam"
[0] #7  __libc_start_main in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[2] #6   in "/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[3] #6   in "/lib64/libc.so.6"
[0] #8  ????Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const?? in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/simpleFoam"
[4] #7  __libc_start_main in "/lib64/libc.so.6"
[4] #8   in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/simpleFoam"
[localhost:22423] *** Process received signal ***
[localhost:22423] Signal: Floating point exception (8)
[localhost:22423] Signal code:  (-6)
[localhost:22423] Failing at address: 0x1f400005797
[localhost:22423] [ 0] /lib64/libc.so.6 [0x3ae10302d0]
[localhost:22423] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3ae1030265]
[localhost:22423] [ 2] /lib64/libc.so.6 [0x3ae10302d0]
[localhost:22423] [ 3] /opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0xc9) [0x2ae2ec5f60e9]
[localhost:22423] [ 4] /opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_RKS7_+0x2c8) [0x2ae2eacd1f28]
[localhost:22423] [ 5] /opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libincompressibleRASModels.so(_ZN4Foam14incompressible9RASModels8kEpsilon7correctEv+0x345) [0x2ae2eacbe795]
[localhost:22423] [ 6] simpleFoam [0x4179e3]
[localhost:22423] [ 7] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3ae101d994]
[localhost:22423] [ 8] simpleFoam(_ZNK4Foam11regIOobject11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0xc1) [0x4148e9]
[localhost:22423] *** End of error message ***
[5] #7  __libc_start_main in "/opt/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/simpleFoam"
[2] #7  __libc_start_main in "/lib64/libc.so.6"
[5] #8  --------------------------------------------------------------------------
mpirun noticed that process rank 0 with PID 22423 on node localhost.localdomain exited on signal 8 (Floating point exception).
Old   May 3, 2011, 03:39
Marta Camps Santasmasas
mcamps is on a distinguished road
Maybe the problem is in your mesh. Have you tried to run checkMesh and see if it find any problem in your mesh?
mcamps is offline   Reply With Quote
Old   May 6, 2011, 08:45
Balakrshnan Ramakrishnan
Balakrshnan Ramakrishnan is on a distinguished road
I am certainly not sure this is work. But I had similar problems and I tried to give low values for relaxation factors for p,U,k,epsilon in the
system/fvSchemes like :
relaxationFactors
p 0.01;
U 0.02;
k 0.02;
epsilon 0.02;
This is because the values of k and epsilon blows up very high that they exceed machine precision like 1.5e200 etc.. This very low relaxation factor will avoid such blow up.
You may need to run more than twice the number of iterations as the convergence will be very slow, but it worked for me.
Also you can give higher number for nOrthogonal Correctors like
SIMPLE
nNonOrthogonalCorrectors 5;
This will also increase computational time but hopefully will try to get better convergence.
Let me know if this helps..
Bala
Balakrshnan Ramakrishnan is offline   Reply With Quote
Thread Tools
Trackbacks are On
Are there anybody study in compute wind engineering ivanyao OpenFOAM Running, Solving & CFD 2 November 25, 2008 22:48
Rough baundary in atmospheric wind majidhojjat OpenFOAM Running, Solving & CFD 3 August 18, 2008 11:15
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
wind engineering problem justin Main CFD Forum 0 February 20, 2006 20:23
Atmospheric Wind Profile - Inlet Subroutine Roger CD-adapco 3 December 12, 2002 11:00
