-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Full pipe 3D using icoFoam (http://www.cfd-online.com/Forums/openfoam/86141-full-pipe-3d-using-icofoam.html)
cyberbrain March 15, 2011 13:07
Hi foamers! hope someone has solution for my problem because i don't know what is going on with my model! :(
First of all i have to mention that i modeled 3D rectangular pipe,unsteady laminar flow, and simulation went fine after some tweaking ... i got stable solution in this case but as soon as i change geometry (with same p,U,boundery fields,fvSolution,fvSchemas...etc) i can't tweak model to convergent. :(
Definition of the problem:
http://img121.imageshack.us/img121/8...ipeproblem.png
This is how I modeled it:
http://img141.imageshack.us/img141/8...pipeblocks.png
My input files:
-blockMeshDict:
convertToMeters 0.1;
vertices
        (-0.15 0 -0.15)
        (0.15 0 -0.15)
        (0.15 0 0.15)
        (-0.15 0 0.15)
        (-0.35355 0 -0.35355)
        (0.35355 0 -0.35355)
        (0.35355 0 0.35355)
        (-0.35355 0 0.35355)
        (-0.15 10 -0.15)
        (0.15 10 -0.15)
        (0.15 10 0.15)
        (-0.15 10 0.15)
        (-0.35355 10 -0.35355)
        (0.35355 10 -0.35355)
        (0.35355 10 0.35355)
        (-0.35355 10 0.35355) );
blocks
            hex (0 3 2 1 8 11 10 9) (10 10 50) simpleGrading (1 1 1)
        hex (0 1 5 4 8 9 13 12) (10 10 50) simpleGrading (1 1 1)
        hex (1 2 6 5 9 10 14 13) (10 10 50) simpleGrading (1 1 1)
        hex (2 3 7 6 10 11 15 14) (10 10 50) simpleGrading (1 1 1)
        hex (3 0 4 7 11 8 12 15) (10 10 50) simpleGrading (1 1 1)
edges
        arc 4 5 (0 0 -0.5)
        arc 5 6 (0.5 0 0)
        arc 6 7 (0 0 0.5)
        arc 7 4 (-0.5 0 0)
        arc 12 13 (0 10 -0.5)
        arc 13 14 (0.5 10 0)
        arc 14 15 (0 10 0.5)
        arc 15 12 (-0.5 10 0)
patches
    patch
        inlet
        (0 3 2 1)
        (0 1 5 4)
        (1 2 6 5)
        (2 3 7 6)
        (3 0 4 7)
    patch
        outlet
        (8 9 10 11)
        (8 12 13 9)
        (9 13 14 10)
        (10 14 15 11)
        (11 15 12 8)
    wall
        walls
        (4 5 13 12)
        (5 6 14 13)
        (6 7 15 14)
        (7 4 12 15)
mergePatchPairs
-controlDict:
application    icoFoam;
startFrom      startTime;
startTime      0;
stopAt          endTime;
endTime        30;
deltaT          1;
writeControl    timeStep;
writeInterval  1;
purgeWrite      0;
writeFormat    ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision  6;
runTimeModifiable yes;
-fvSchemes:
ddtSchemes
        default        Euler;
//        default                steadyState;
gradSchemes
    default        Gauss linear;
    grad(p)        Gauss linear;
divSchemes
    default        none;
    div(phi,U)      Gauss linear;
laplacianSchemes
    default        none;
    laplacian(nu,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
interpolationSchemes
    default        linear;
    interpolate(HbyA) linear;
snGradSchemes
    default        corrected;
fluxRequired
    default        no;
    p              ;
-fvSolution:
solvers
    p
        solver                PCG;
        preconditioner        DIC;
        tolerance        1e-06;
        reTol                0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance      1e-05;
        relTol          0;
PISO
    nCorrectors    2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue      0;
- 0/p
dimensions      [0 2 -2 0 0 0 0];
internalField  uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value                uniform 0;
    walls
        type            zeroGradient;
-0/U
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value          uniform (0 1 0);
    outlet
        type          zeroGradient;
    walls
        type            fixedValue;
        value                uniform (0 0 0);
So as u can see i need velocity on inlet (0 1 0) and presure an outlet (0)...
really can't find problem...maybe icoFoam is not solver that i should use for this problem...any sugestion would be great!
finally these errors and results i get on calculation:
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 1
Courant Number mean: 0 max: 100
DILUPBiCG:  Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 7.24921e-06, No Iterations 35
DILUPBiCG:  Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG:  Solving for p, Initial residual = 1, Final residual = 9.26667e-07, No Iterations 151
time step continuity errors : sum local = 9.26667e-07, global = 8.46286e-09, cumulative = 8.46286e-09
DICPCG:  Solving for p, Initial residual = 0.00918897, Final residual = 9.76998e-07, No Iterations 136
time step continuity errors : sum local = 9.97464e-05, global = -9.91256e-07, cumulative = -9.82793e-07
ExecutionTime = 1.41 s  ClockTime = 2 s
Time = 2
Courant Number mean: 4.98906 max: 143.985
DILUPBiCG:  Solving for Ux, Initial residual = 0.751531, Final residual = 9.97711e-06, No Iterations 28
DILUPBiCG:  Solving for Uy, Initial residual = 0.313552, Final residual = 8.39474e-06, No Iterations 29
DILUPBiCG:  Solving for Uz, Initial residual = 0.75153, Final residual = 7.57783e-06, No Iterations 29
DICPCG:  Solving for p, Initial residual = 0.49221, Final residual = 8.38074e-07, No Iterations 147
time step continuity errors : sum local = 1.2671e-05, global = -8.75128e-09, cumulative = -9.91545e-07
DICPCG:  Solving for p, Initial residual = 0.0117698, Final residual = 7.11563e-07, No Iterations 137
time step continuity errors : sum local = 0.000408209, global = 2.92362e-06, cumulative = 1.93208e-06
ExecutionTime = 2.49 s  ClockTime = 3 s
Time = 3
Courant Number mean: 26.4226 max: 916.486
DILUPBiCG:  Solving for Ux, Initial residual = 0.809749, Final residual = 9.30861e-06, No Iterations 31
DILUPBiCG:  Solving for Uy, Initial residual = 0.389871, Final residual = 7.63744e-06, No Iterations 40
DILUPBiCG:  Solving for Uz, Initial residual = 0.809748, Final residual = 9.34365e-06, No Iterations 36
DICPCG:  Solving for p, Initial residual = 0.604599, Final residual = 9.48499e-07, No Iterations 147
time step continuity errors : sum local = 8.65678e-05, global = 1.26445e-07, cumulative = 2.05852e-06
DICPCG:  Solving for p, Initial residual = 0.0148976, Final residual = 7.70586e-07, No Iterations 137
time step continuity errors : sum local = 0.00252944, global = -1.84451e-05, cumulative = -1.63866e-05
ExecutionTime = 3.67 s  ClockTime = 4 s
Time = 4
Courant Number mean: 147.201 max: 4510.08
DILUPBiCG:  Solving for Ux, Initial residual = 0.77792, Final residual = 9.67807e-06, No Iterations 73
DILUPBiCG:  Solving for Uy, Initial residual = 0.489883, Final residual = 5.18925e-06, No Iterations 73
DILUPBiCG:  Solving for Uz, Initial residual = 0.77792, Final residual = 6.03916e-06, No Iterations 73
DICPCG:  Solving for p, Initial residual = 0.694876, Final residual = 8.19978e-07, No Iterations 148
time step continuity errors : sum local = 0.000558808, global = 2.33549e-06, cumulative = -1.40511e-05
DICPCG:  Solving for p, Initial residual = 0.0226691, Final residual = 6.59866e-07, No Iterations 139
time step continuity errors : sum local = 0.0122011, global = 9.60505e-05, cumulative = 8.19994e-05
ExecutionTime = 5.32 s  ClockTime = 5 s
Time = 14
Courant Number mean: 2.95062e+86 max: 2.42912e+89
DILUPBiCG:  Solving for Ux, Initial residual = 0.998523, Final residual = 1.01741e+07, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.994646, Final residual = 2.2903, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999568, Final residual = 69.2939, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 35.9498, No Iterations 1001
time step continuity errors : sum local = 1.53483e+98, global = -3.01763e+92, cumulative = -3.01763e+92
DICPCG:  Solving for p, Initial residual = 0.950592, Final residual = 54.6822, No Iterations 1001
time step continuity errors : sum local = 2.09996e+101, global = -1.03985e+97, cumulative = -1.03988e+97
ExecutionTime = 142.67 s  ClockTime = 143 s
Time = 15
Courant Number mean: 1.99707e+101 max: 2.02545e+104
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/icoFoam"
#6  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
And finaly resultat is crap! (pressure field seems fine on first time step...after that goes crazy)...
http://img688.imageshack.us/img688/7...fieldtime1.png
http://img51.imageshack.us/img51/154...fieldtime3.png
http://img856.imageshack.us/img856/9...fealdtime1.png
http://img638.imageshack.us/img638/8...fieldtime3.png
Thanks in advance...my CFD knowledge was based on basics of Finite Elements method...so Finite Volumes is something new for me...so sorry for some stupid mistakes if i made using OpenFOAM!
regards!
Petar Zivkovic
MartinB March 15, 2011 13:21
Hi Petar,
reduce deltaT in system/controlDict to a much lower value, say 0.001, and try again.
Martin
cyberbrain March 15, 2011 14:16
Hi Matin,
Thanx for quick replay... but same problem occurred:
Time = 0.015
Courant Number mean: 15.6518 max: 277.137
DILUPBiCG:  Solving for Ux, Initial residual = 0.745384, Final residual = 8.16797e-06, No Iterations 53
DILUPBiCG:  Solving for Uy, Initial residual = 0.78606, Final residual = 8.31362e-06, No Iterations 50
DILUPBiCG:  Solving for Uz, Initial residual = 0.745302, Final residual = 5.90854e-06, No Iterations 50
DICPCG:  Solving for p, Initial residual = 0.904914, Final residual = 8.3528e-07, No Iterations 227
time step continuity errors : sum local = 6.3841e-05, global = -1.01036e-07, cumulative = -3.16388e-07
DICPCG:  Solving for p, Initial residual = 0.713999, Final residual = 9.34143e-07, No Iterations 221
time step continuity errors : sum local = 0.000113492, global = -2.62634e-08, cumulative = -3.42651e-07
ExecutionTime = 17.02 s  ClockTime = 17 s
Time = 0.016
Courant Number mean: 69.3057 max: 50974.2
DILUPBiCG:  Solving for Ux, Initial residual = 0.999403, Final residual = 0.0429228, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.998282, Final residual = 0.426477, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999378, Final residual = 0.0676183, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 0.979382, Final residual = 8.03998e-07, No Iterations 762
time step continuity errors : sum local = 0.00285593, global = 2.08686e-06, cumulative = 1.7442e-06
DICPCG:  Solving for p, Initial residual = 0.993121, Final residual = 5.441e-07, No Iterations 869
time step continuity errors : sum local = 0.368197, global = 0.00145017, cumulative = 0.00145192
ExecutionTime = 33.06 s  ClockTime = 33 s
Time = 0.017
Courant Number mean: 2.25409e+06 max: 1.33605e+10
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 1.26774, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 6.16202, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 14331.8, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 2.86475, No Iterations 1001
time step continuity errors : sum local = 5.61093e+18, global = 3.57396e+12, cumulative = 3.57396e+12
DICPCG:  Solving for p, Initial residual = 0.998461, Final residual = 6.10091, No Iterations 1001
time step continuity errors : sum local = 2.83525e+22, global = -7.04584e+16, cumulative = -7.04548e+16
ExecutionTime = 49.9 s  ClockTime = 51 s
Time = 0.018
Courant Number mean: 2.82832e+22 max: 3.0603e+25
DILUPBiCG:  Solving for Ux, Initial residual = 0.998746, Final residual = 34.4554, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.997935, Final residual = 1.09843, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999978, Final residual = 5.21295, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 994.164, No Iterations 1001
time step continuity errors : sum local = 9.01643e+34, global = -1.1094e+25, cumulative = -1.1094e+25
DICPCG:  Solving for p, Initial residual = 0.854007, Final residual = 2.57049, No Iterations 1001
time step continuity errors : sum local = 1.51861e+36, global = -5.055e+28, cumulative = -5.05611e+28
ExecutionTime = 68.06 s  ClockTime = 70 s
Time = 0.019
Courant Number mean: 1.47917e+36 max: 6.46245e+39
DILUPBiCG:  Solving for Ux, Initial residual = 0.99976, Final residual = 1.32634, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.999817, Final residual = 2.27595, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999836, Final residual = 1.46444, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 14.1995, No Iterations 1001
time step continuity errors : sum local = 1.57509e+45, global = -5.09557e+40, cumulative = -5.09557e+40
DICPCG:  Solving for p, Initial residual = 0.961166, Final residual = 1.84414, No Iterations 1001
time step continuity errors : sum local = 1.29718e+47, global = 5.31671e+42, cumulative = 5.26575e+42
ExecutionTime = 85.08 s  ClockTime = 87 s
Time = 0.02
Courant Number mean: 1.13079e+47 max: 1.72878e+50
DILUPBiCG:  Solving for Ux, Initial residual = 0.999672, Final residual = 3.36115, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.999739, Final residual = 1.97782, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999953, Final residual = 1.26137, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 26.5917, No Iterations 1001
time step continuity errors : sum local = 5.52811e+54, global = -1.50009e+47, cumulative = -1.50004e+47
DICPCG:  Solving for p, Initial residual = 0.968712, Final residual = 3.96145, No Iterations 1001
time step continuity errors : sum local = 6.76349e+56, global = 4.68529e+51, cumulative = 4.68514e+51
ExecutionTime = 102.04 s  ClockTime = 104 s
Time = 0.021
Courant Number mean: 6.15008e+56 max: 1.0711e+60
DILUPBiCG:  Solving for Ux, Initial residual = 0.999863, Final residual = 2.39706, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.999311, Final residual = 2.89499, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999239, Final residual = 9.1686, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 6.74239, No Iterations 1001
time step continuity errors : sum local = 9.93366e+62, global = 8.94398e+59, cumulative = 8.94398e+59
DICPCG:  Solving for p, Initial residual = 0.969226, Final residual = 5.91848, No Iterations 1001
time step continuity errors : sum local = 1.60358e+65, global = -3.91343e+61, cumulative = -3.82399e+61
ExecutionTime = 118.84 s  ClockTime = 121 s
Time = 0.022
Courant Number mean: 1.4642e+65 max: 1.56676e+68
DILUPBiCG:  Solving for Ux, Initial residual = 0.999892, Final residual = 14.4943, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.997566, Final residual = 314.253, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999563, Final residual = 47.8097, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 6.72161, No Iterations 1001
time step continuity errors : sum local = 2.74648e+72, global = 3.28068e+68, cumulative = 3.28068e+68
DICPCG:  Solving for p, Initial residual = 0.994044, Final residual = 1.4551, No Iterations 1001
time step continuity errors : sum local = 6.07386e+74, global = -3.00558e+70, cumulative = -2.97277e+70
ExecutionTime = 135.7 s  ClockTime = 139 s
Time = 0.023
Courant Number mean: 4.83037e+74 max: 2.49651e+78
DILUPBiCG:  Solving for Ux, Initial residual = 0.999758, Final residual = 1.13815, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.999584, Final residual = 6.9745, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999761, Final residual = 1.2188, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 4.16214, No Iterations 1001
time step continuity errors : sum local = 7.19249e+80, global = 3.93959e+77, cumulative = 3.93959e+77
DICPCG:  Solving for p, Initial residual = 0.974832, Final residual = 1.65162, No Iterations 1001
time step continuity errors : sum local = 5.25285e+82, global = 4.10531e+78, cumulative = 4.49927e+78
ExecutionTime = 153.07 s  ClockTime = 157 s
Time = 0.024
Courant Number mean: 4.6552e+82 max: 5.73544e+85
DILUPBiCG:  Solving for Ux, Initial residual = 0.999591, Final residual = 45.7348, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.996466, Final residual = 20.3214, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.998556, Final residual = 7.91727, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 1.49843, No Iterations 1001
time step continuity errors : sum local = 6.52806e+88, global = -2.50005e+84, cumulative = -2.50005e+84
DICPCG:  Solving for p, Initial residual = 0.994329, Final residual = 47.8821, No Iterations 1001
time step continuity errors : sum local = 2.26097e+92, global = -1.25671e+88, cumulative = -1.25696e+88
ExecutionTime = 170.12 s  ClockTime = 174 s
Time = 0.025
Courant Number mean: 2.18709e+92 max: 1.36393e+95
DILUPBiCG:  Solving for Ux, Initial residual = 0.998666, Final residual = 9754.69, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.997946, Final residual = 7535.41, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999833, Final residual = 303.156, No Iterations 1001
#2  Uninterpreted:
#3  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libfiniteVolume.so"
It seems like there is continuality problem somewhere...but i can't find it... :(
This is basic example...there should no be problem solving this...
I'm just afraid that i'm doing something wrong on basic stuff...(mesh or something like that)...but checkMesh returns "mesh OK".. :(
MartinB March 15, 2011 15:18
1 Attachment(s)
Hi Petar,
your case works fine for me, tested on 1.6.x and 1.6-ext... can you try the attached case?
As a general rule you should keep the max courant number below 0.5 by choosing an appropriate time step. The rest of your settings seem to be fine.
Best regards
Martin
cyberbrain March 16, 2011 10:20
Thanks a lot for your effort martin...you gave me direction for solving my problem...i'm abuout to find out what you have done so i'll try to modify my files and see if i can tweak it...(it seems you have added some extra parameters and files then I have)...
your example works fine...it seems that it was problem with viscosity and time step at the same time...
tnx a lot!
if i had some questions or suggestions that may help someone in future, i'll post it here!
Petar. :)
