March 16, 2011, 12:13 |
Unsteady condition for oscillating wing
Rep Power: 15 |
Dear all,
I would like to simulate to flow around a 2D airfoil that oscillates at high angle of attack using pisoFoam. To do so, the first idea that came out of my mind was to keep the airfoil at is angle of attack and impose an unsteady condition on the upstream flow such as: , where the function alpha(t) is defined by the user. Someone has any clues on how I should make this work? Thanks in advance, L1011 |
March 17, 2011, 08:55 |
Olivier
Rep Power: 17 |
Look at GroovyBC ... Olivier P.S: what 's your final settings for airfoil simulation now ? |
March 17, 2011, 15:14 |
vinny
Rep Power: 15 |
Hi All,
I also wanted to do simulation around 2d oscillating airfoil. I tried pimpleDymFoam with dynamic meshing. I used sixDoFRigidBody BC. I am getting the movement of airfoil but not what I wanted. I didnt try groovy BC. Will this groovy BC be useful.. Please someone suggest me ...I dont know whether I am going in the right direction. |
March 18, 2011, 07:23 |
Rep Power: 16 |
I also work on flapping foils, and at first I also thought to simply apply variable boundary velocities instead of moving the foil. Frank Bos, however, told me that this would give a very "stiff" system of equations, which is hard to solve. Vinny, if you pass me your case with pimpleDyMFoam, I will take a look at it. You can mail it to snedige@yahoo.com. |
March 23, 2011, 14:59 |
vinny
Rep Power: 15 |
Hi Flowris,
Thank you for the reply. I have sent you the pointDisplacement file through mail. I suppose this would help. Also it would be helpful if anyone tell me about groovy BC.. |
April 15, 2011, 15:34 |
Rep Power: 15 |
Sorry for my late response, I've been in a rush for the past weeks.
@olivierG: I'll post my case in the coming days Up to now I've been investigating two promising solution:
Thanks for sharing your ideas/progress! L1011 |
September 19, 2018, 08:25 |
#7 | |
Milad
Rep Power: 8 |
This is my problem too. I can not import my mesh in OF because of problems. What is the main boundary condition for pitching airfoil? |
Adding heat source to chtMultiRegionFoam | maddalena | OpenFOAM Programming & Development | 61 | February 17, 2018 08:33 |
Convective outlet boundary condition for Unsteady flows | msrinath80 | OpenFOAM Running, Solving & CFD | 109 | November 28, 2016 10:53 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 00:55 |
CFX Solver : Sudden crash | Hervé | CFX | 2 | June 16, 2008 06:40 |
