March 18, 2011, 06:07 |
simpleSRFFoam in OpenFOAM 1.5-Dev
Kurne
Rep Power: 15 |
Dear All
I have install OpenFOAM 1.5-Dev as per instruction given here http://openfoamwiki.net/index.php/Installation But the problem is that i am not getting any tutorials file and i want to use simpleSRFFoam and MRFsimpleFoam but how to use it.I want to ask that after installation where the all files are installed and how to use simpleSRFFoam and MRFsimpleFoam for my case.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne |
March 18, 2011, 15:22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kurne,
Run this to install the files necessary for building the version you installed: Code:
sudo apt-get install openfoam-dev-1.5-dev Code:
echo $FOAM_TUTORIALS ls -l $FOAM_TUTORIALS Code:
mkdir -p $FOAM_RUN cp -r $FOAM_TUTORIALS $FOAM_RUN Bruno
March 18, 2011, 22:28 |
Kurne
Rep Power: 15 |
Dear Bruno
Thanks a lot Bruno.You are really a Rocking guy in OpenFOAM.I have been stuck up with this from couple of days.I have solved my problem with the help of you. Thanking You Once Again. Take Care.
[OpenFOAM] ParaFoam instalation in OpenFoam 1.5 dev | titio | ParaView | 2 | July 24, 2010 23:24 |
OpenFOAM 1.5 dev | LVDH | OpenFOAM | 98 | May 5, 2010 17:01 |
[OpenFOAM] ParaView/ParaFoam in OpenFoam 1.5 dev | titio | ParaView | 2 | February 27, 2010 14:02 |
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev | titio | ParaView | 0 | December 9, 2009 12:13 |
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev | titio | ParaView | 0 | December 9, 2009 12:12 |
