-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Problem in running job in parallel (http://www.cfd-online.com/Forums/openfoam/86329-problem-running-job-parallel.html)
Tarak March 19, 2011 21:34
Hii,
I am getting the following kind of error after I submit a job in parallel in OF. Although the sequential run is perfectly OK.
[node081:31181] Error: unknown option "--bootproxy"
[node079:22646] Error: unknown option "--bootproxy"
input in flex scanner failed
[node082:30741] ERROR: A daemon on node node082 failed to start as expected.
[node082:30741] ERROR: There may be more information available from
[node082:30741] ERROR: the remote shell (see above).
[node082:30741] ERROR: The daemon exited unexpectedly with status 2.
[node082:30741r ERROR: A daemon on node node074 failed to start as expected.
Can you please help me locate where the problem is. Seems like a MPI issue.
Thanks,
Tarak
