chtMultiRegionFoam + Sphere mesh + makeCellset.setSets
Hello friends,
I am using chtmultiregion foam to solve my problem. I changed the chtmultiregionFoam solve according to my requirement and I run on heater problem which gave perfect result. But, I need sphere in my problem instead of heater. Two spheres are in one cube. I also found the command "cylinderToCell" from utilities/mesh/manipulation/cellsets. In heater problem, the geometry is simple, hence, it is easy to define by blockMesh and after that by makeCellSet.setSets. But, for sphere, how we can define in blockMeshDict and makecellSet.setSet file? can we define cube in blockMeshDict and sphere from makecellset.setset file by using cylinderToCell command? if yes, how we can subtract a sphere from the cube? Or should I have to use snappyHexMesh? then, can snappyHexMesh combine in shtmultiregionfom for two different region? or should I have to make a geometry in gmsh or any other software and import in opefoam? please, tell me which one is possible and easy.. Thanx in advance kind regards Alpesh |
Hello Alpesh,
It is even easier than that. You can use sphereToCell cellSet c0 new sphereToCell (cx cy cz) R Usage: sphereToCell (centreX centreY centreZ) radius Select all cells with cellCentre within bounding sphere Good luck, Frederic PS: Remember that the sphere won't have a spherical shape but will be approximate by the elements (probably hexahedrons) of the mesh. If you really need a good surface, you will have to move to dedicated mesh tools. |
Hi Frederic Collonval,
Thank you very much for your reply... I tried with that and I got sphere shape but it is not really sphere.. I think I have to use very dense mesh..then surface will transform in spherical shape.. But, I am getting problem in surrounding air region.. should I have to define surrounding region in makecellsets.setset or in blockmeshDict? regards alpesh |
Generate geometry for multi-domain simulation
rm -rf constant/polyMesh/sets //remove the previous sub-parts of the mesh Good luck, Frederic |
Thank you very much for your help.. I tried and it's working perfectly.. but, when I tried to make dense mesh, some pointer error came. so, I think I have to make mesh in other opensource pre-processing software to get perfect sphere shape. can I do that way? again thanx alt.. regards Alpesh |
