April 6, 2022, 08:36 |
"blockMesh command not found"
Rep Power: 5 |
Hello everyone,
I recently installed openfoam on a cluster. I tried to run blockMesh function but got the message "command not found". Then I saw i should source my openfoam bashrc, which i did. But then i got the message "openfoam (etc/config.sh/mpi) => invalid INTELMPI directory => unset Please set I_MPI_ROOT or MPI_ROOT correctly." Then i re-tried to run blockMesh but got a different message : "blockMesh: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directory" Do you have any idea of how to solve my issue? Thanks a lot |
April 6, 2022, 22:14 |
#2 | |
Ashutosh
Rep Power: 4 |
error "specified procedure not found" CFX solver | BOUALOUACHE | CFX | 5 | January 9, 2022 12:56 |
"Plugin error no valid bodies found" | 9ashdav6 | CFD Freelancers | 1 | February 24, 2021 17:30 |
"PlugIn Error: Geometry interface not found" When MESHING | maio7 | FLUENT | 0 | April 12, 2017 11:41 |
How to fix problem with "decomposePar: command not found"? | mchehab2 | OpenFOAM Running, Solving & CFD | 2 | March 31, 2016 06:26 |
"No FvBoundary found" | Jambond | STAR-CCM+ | 2 | October 20, 2015 08:41 |
