Suppress interpolationTable overflow messages
Old   March 22, 2011, 16:01
Default Suppress interpolationTable overflow messages
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
I'm using an interpolation table and the values in my simulation run beyond the maximum value of the table. I'd still like to run the simulation until I can compile a new table; is there a way of supressing the message, preferably without recompiling the libraries (I only want this temporarily for select cases).
Thanks in advance!
mturcios777 is offline   Reply With Quote
Old   March 23, 2011, 13:04
Marco A. Turcios
Ugh, I hate it when some simple digging will find the answer. Now I have to come here, post the answer and look silly
I was originally creating the interpolationTable by referencing the filename directly, with the constructor:
interpolationTable <scalar> myTable(fileName)
I found there to be several different constructors, including one where you can specify the outOfBounds behavior to warn, clamp, repeat
Since I do a lot of changes at run time, I found it best to use a dictionary that contains the file name and the outOfBounds behavior:
in createFields.H
interpolationTable<scalar> myTable(myDict)
in constant/myDict
fileName        "path/to/my/file.dat";
outOfBounds        clamp;
Last edited by mturcios777; March 23, 2011 at 13:10. Reason: removed caps on outOfBounds specifiers
Old   April 6, 2022, 09:52
Cool Problem in defining outOfBounds w. interpolation2DTable
Julian Re
JuRe09 is on a distinguished road
in createFields.H
in constant/myDict
outOfBounds        clamp;
Basically I have the same problem! I get the Warn message that an value is out of bounds which is true. My definition (construc using dict) is as follows:
myTable = interpolation2DTable<scalar>("constant/myDict");
and in constant/myDict:
fileName "constant/myTable";
 outOfBounds clamp;
I get the following error:
1] --> FOAM FATAL IO ERROR:
[1] Expected a '(' while reading Tuple2, found on line 1: word 'fileName'
[1]
[1] file: constant/myDict at line 1.
[1]
[1] From function Foam::Istream& Foam::Istream::readBegin(const char*)
[1] in file db/IOstreams/IOstreams/Istream.C at line 92.
[1]
FOAM parallel run exiting
Note: When i use the constructor just using fName = "constant/myTable" it works fine expect the bounds handling....
JuRe09 is offline   Reply With Quote
Solution variables goes outside upper limit -how to localize fatal overflow occurance Dimone CFX 2 January 21, 2011 06:35
OVERFLOW and Horizontal Axis Wind Turbine ntonkin Main CFD Forum 1 November 19, 2009 01:40
Assembler messages when compiling on AMD64 hani OpenFOAM 4 May 22, 2006 08:08
No warning or error messages found. Atit Koonsrisuk CFX 5 January 14, 2003 11:06
linear solver overflow peggy CFX 1 February 8, 2001 01:39
