-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   FixedFLuxPressure error (http://www.cfd-online.com/Forums/openfoam/86507-fixedfluxpressure-error.html)
Andrea_85 March 24, 2011 07:26
Hi all,
i'm trying to run a test simulation using interFoam. I would like to test the difference between limit "zeroGradient" and limit "gradient" in the constantContactAngle patch. When i run limit "zeroGradient" everythink is fine but when i use limit "gradient" i get this error:
Cannot find 'value' entry on patch wall.4 of field p_rgh in file "/home/aferrari/Simulation/OstacoliRandom/simm2e-2alpha30/simmetricou2e-2relaxsmooth_limitgradient/0/p_rgh"
which is required to set the values of the generic patch field.
(Actual type fixedFLuxPressure)
Please add the 'value' entry to the write function of the user-defined boundary-condition
or link the boundary-condition into libfoamUtil.so
file: /home/aferrari/Simulation/OstacoliRandom/simm2e-2alpha30/simmetricou2e-2relaxsmooth_limitgradient/0/p_rgh::boundaryField::wall.4 from line 263883 to line 263884.
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&)
in file genericFvPatchField/genericFvPatchField.C at line 71.
my p_rgh file is simply
wall.4
type fixedFLuxPressure;
adjoint no;
and I do not think you need to specify a "value". So what's the problem?
Thanks
andrea
