a problem with temperature depending properties
Old   March 28, 2011, 01:03
Default a problem with temperature depending properties
Maryam Mousazadeh
anijdon is on a distinguished road
hello
I want to simulate a case with nanofluid. I extracted transport and thermal properties equation which are conclude tow fluid and nanoparticles properties (in first method that you said). but viscosity and conductivity are temperature dependent. I tried to use thermophysical models but I didn't find where put the equations .however this way may be wrong. I add energy equation to simpleFoam and want to modify this solver to my simulation.
do you have any opinion to help me.
kind regards
anijdon is offline   Reply With Quote
Old   March 29, 2011, 04:48
Ulrich Heck
ulli is on a distinguished road
Anijdon,
there is an example, in the latest OF 1.7.1/x-release for the cht-solver, where a incompressible liquid with temperature dependant properties is solved. This one is based on the hRho-Thermo definitions and uses the icoPolynominal property definition. You can take this solver or check the other heattransfer and "compressible" solvers, if they allow the same property definition.
Hope this helps
Ulrich
ulli is offline   Reply With Quote
Old   March 29, 2011, 17:46
Maryam Mousazadeh
hello Ulrich;
thank you for your guidance. If I'm not wrong, in that example that you say it is use thermophysical model. I'm not familar with thermophysical model very much but what I understand is that they are based on specified formulas.I attach the formuls file of my case:
formuls.zip
thanks;
PorousMedia Problem with Temperature Distribution pawan OpenFOAM Running, Solving & CFD 2 August 2, 2015 23:08
static temperature is higher than total temp. in buoyancy problem amirbahador FLUENT 2 October 24, 2010 07:21
rotationally periodic properties vs temperature Sasha FLUENT 0 April 7, 2008 13:13
the material parameters depending on temperature Jason CFX 4 December 22, 2006 19:54
Problem with transport properties depending on Temperature galaad OpenFOAM Running, Solving & CFD 5 December 6, 2005 12:51
