air - simpleFoam
I want to know, how i can set up the fluid in simpleFoam, for example to set up the fluid as water or as air. I don't find a file like thermophysical properties like it can be found in chtMulti. I guess that's because of the heat transfer. But where can I type in the properties of air, for example the molecular weight,...? I guess that simpleFoam only needs the information newtownian fluid and for every newtonian fluid the result of the simulation with simpleFoam is neraly the same. Do I guess right? :-) Best Regards, tH3f0rC3 |
Hi, in simpleFoam you set the fluid properties via nu in "constant/transportProperties". For example air at 20 °C: Code:
transportModel Newtonian; Regards, Toni |
Thank you for you answer.
So it is meant the dynamic viscosity, isn't it? More information the solver doesn't need to solve the Navier-Stokes-equaions?! Best Regards, tH3f0rC3 |
nu is the Kinematic viscosity nu nu [0 2 -1 0 0 0 0] 1.5e-05; you can see it in the unit: nu [0 2 -1 0 0 0 0] --> m²/s , have a look at the user-guide, chapter 4 regards, Jean |
Oh :(
That was a very stupid question. I know that the units are represented by numbers in these brackets. Thank you for your answer! :-) The data below transportModel Newtonian; nu nu [..] ... CROSSPOWERLAWCOEFF... Are these data also properties of the air or are they speciefic for the solver? Best Regards, tH3f0rC3 |
nu nu [0 2 -1 0 0 0 0] 1.5e-05; --> kinematic viscosity of the fluid. Jean |
hi dirk,
as far as i know this properties are irrelevant if you are simulating with a newtonian fluid. These entries are only needed if you choose another transport model (like CrossPowerLaw for example). |
Ah ok, thank you! :-)
