Running in parallel
Old   February 24, 2005, 10:41
Default Hi, I am just testing the p
Rasmus Gjesing (Gjesing)
I am just testing the parallel-feature on to nodes before setting up a hopefully bigger cluster.
But I ran into problems...
I use ssh with LAM and that works fine. tping returns correctly from my local and remote node.
But when I make a mpirun,
mpirun -np 2 icoFoam $FOAM_RUN/tutorials/icoFoam cavityPar -parallel < /dev/null >& log &
as written in the guide, it returns the following...
P.S. I have decomposed the case and the processor directories and files are present?
Any suggestions?
/Rasmus
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.0.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : icoFoam /home/rg/OpenFOAM/rg-1.0.2/run/tutorials/icoFoam cavityPar -parallel
Date : Feb 24 2005
Time : 16:28:24
Host : serie020-lease-041.intern.ipl
PID : 7119
Date : Feb 24 2005
Time : 16:28:24
Host : foamcalculator.intern.ipl
PID : 7331
[1] Root : /home/rg/OpenFOAM/rg-1.0.2/run/tutorials/icoFoam
[1] Case : cavityPar
[1] Nprocs : 2
[0] Root : /home/rg/OpenFOAM/rg-1.0.2/run/tutorials/icoFoam
[0] Case : cavityPar
[0] Nprocs : 2
[0] Slaves :
1
foamcalculator.intern.ipl.7331
Create database
--> FOAM FATAL ERROR : icoFoam: Cannot open case directory "/home/rg/OpenFOAM/rg-1.0.2/run/tutorials/icoFoam/cavityPar/processor1"
Function: argList::checkRootCase() const
in file: global/argList/argList.C at line: 511.Create mesh for time = 0
FOAM parallel run exiting
Old   February 25, 2005, 03:49
Default This is from someone who just
Fabian Peng Kärrholm (Kärrholm)
This is from someone who just started his first paralell case a few minutes ago, but from the error message, it sounds like you haven't decomposed your case properly.
Have you checked that you have selected the same number of subdomains, processors etc? And that you have a polyMesh and a 0 directory in the processor0 and processor1 directories? And that they are all readable?
Old   February 25, 2005, 04:09
Default I am pretty sure my decomposi
I am pretty sure my decomposition is ok, since I can run the decomposed case on one local processor. I think my problem is the connection to the remote eventough I can tping it and boot lam succesfully.
Are you also using ssh or rsh?
/Rasmus
P.S. I am using Redhat 9 if that adds extra knowledge?!
Old   February 25, 2005, 04:14
Default Hi Rasmus, Can your remote
Mattijs Janssens (Mattijs)
Hi Rasmus,
Can your remote computer read your files? Is nfs working ok or maybe the protection bits are causing problems?
Mattijs
Old   February 25, 2005, 05:34
Default Hi Mattijs, I think you on
Hi Mattijs,
I think you on the track of something, because my nfs was disabled, but now enabled, however still problems...
I can run the decomposed case on my local node, but the remote causes problems. I have just tried running the case ONLY on the remote and now this is the error I get.
--> FOAM FATAL IO ERROR : Istream not OK for reading dictionary
file: /home/rg/OpenFOAM/rg-1.0.2/run/tutorials/icoFoam/cavityPar/system/decomposeParDict at line 1.
Function: dictionary::read(Istream&, const word&)
in file: db/dictionary/dictionaryIO.C at line: 44.
So, it is the permissions that are teasing me.
How can I fix this?
Regards,
Rasmus
BTW. my decomposeParDict is like this...
numberOfSubdomains 2;
method simple;
simpleCoeffs
n (2 1 1);
delta 0.001;
hierarchicalCoeffs
n (2 1 1);
delta 0.001;
order xyz;
metisCoeffs
processorWeights
1
1
manualCoeffs
dataFile "";
distributed no;
roots
Old   March 2, 2005, 11:36
Default Hi, I can now run on to PC
I can now run on to PC's, but I am not satisfied with my solution so far.
I have two identical users on the server and client, let us say their are named myUser. So both on the server and the client there exists a directory /home/myUser.
To get mpirun to run I have mounted server:/home/myUser as /home/myUser on the client. This is of course not so ideal, I think.
How can I mount so the application can run without installing OpenFOAM on all the nodes. Any suggestions?
/Rasmus
P.S. Got a 1.3 speedup for 2 nodes with normal network and one of the nodes being a laptop?!
Old   March 2, 2005, 12:59
Default Hi Rasmus about your 1.3 s
Hi Rasmus
about your 1.3 speedup: that does not seem very surprising. We once tested the comms speed on my laptop and it was nowhere near 100Mb/s. For decent network speed and large enough cases the speedup will be much higher.
Mattijs
Old   March 2, 2005, 18:47
Default Running on a cluster or any o
Eugene de Villiers (Eugene)
Running on a cluster or any other parallel enviroment, you would generally use the following:
1. On ALL nodes, mount the partition with the user home directory via nfs. This does mean you must have the same user account on all nodes, but this can be easily accomplished via NIS if you have many nodes, or my via a GUI or editing the /etc/passwd file if you have two or three and dont feel comfortable with NIS. I dont know of any parallel code that uses a different method and this is the standard cluster setup.
2. On ALL nodes mount the partition with the OpenFOAM installation via nfs. The mount must have the same name on all nodes otherwise your startup script wont be able to find the OpenFOAM installation. Best practice is to use automounter to accomplish the nfs mountings, since it will automatically make softlinks for local partition mounts (see "man automount") which might otherwise cause problems. (of course, if OpenFOAM is installed IN your user directory or on the same partition, you will only need one nfs mount per node, the rest still applies)
3. Make sure you have passwordless ssh access to all nodes, including the master node. Passwordless ssh can be set up via ssh-keygen (see "man ssh-keygen")
Provided all machines meet the specs, the lot should work.
Old   March 9, 2005, 10:31
Default I used to be able to run cases
kärrholm
I used to be able to run cases in paralell using suse, but when switching to debian I got the same error as Rasmus Gjesing, namely:
file: ../LesSmallCavityFine.p/system/decomposeParDict at line 1.
Did you ever find out what caused this? I have my files mounted using NIS, so they are the same on all three computers.
/Fabian
Old   March 9, 2005, 10:49
Default Hi Fabian, Yes, I solved my
Rasmus Gjesing
gjesing is on a distinguished road
Hi Fabian,
Yes, I solved my problem. First of all my nfs-service wasn't running ( minor detail ;-) ). Then I also created the same user on all the nodes and on the server, and mounted my home-directory from the server as the home-directory on each node. Then the nodes has access to all the files they need.
/Rasmus
gjesing is offline   Reply With Quote
Old   September 14, 2005, 07:32
Default Hello everyone, I´ve got some
  #11
Rolando Maier
rolando is on a distinguished road
Hello everyone,
I´ve got some problems, running OpenFOAM in parallel. Maybe someone can give me a hint.
I´ve written some routines, which work quite good on a single processor but make some problems when I try running them in parallel.
I´m working with a GeometricField and I want to determ it´s size and do some operations with each of its elements. Therefore I use GeometricField.size() and forAll(GeometricField, ele){ ... } (which uses also the size method, if I´m right).
The problem is, that the size, which is determined in parallel is much to small (about that size one would expect on just one processor).
Am I doing something wrong?
Rolando
rolando is offline   Reply With Quote
Old   September 14, 2005, 07:49
Default You should rewrite your code f
  #12
Hrvoje Jasak
You should rewrite your code for parallel:
In the domain decomposition mode, each processor only sees its own bit of the field or the mesh. Also, you cannot rely on data numbering (points, faces, cells, etc) because there is no mapping available between the local numbers on the processor and global numbering (unless you really really know what you're doing).
Hrv
Hrvoje Jasak
Old   September 14, 2005, 08:07
Default Thanks for the hint Hrvoje, I
  #13
Rolando Maier
I think I´ve got it now. I had to remember my little MPI knowledge. I used the reduce( ... ) operation for determing the total field size. Now it works.
Rolando
Old   August 8, 2006, 08:06
Default about your 1.3 speedup: that d
  #14
Quinn Reynolds
quinnr is on a distinguished road
Hi, we're busy testing OpenFOAM 1.3 for use in high temperature metallurgy applications.
We have an existing cluster of four P4 2.2GHz nodes on a 100Mbps Ethernet network. My initial testing suggests that we're only going to start seeing a speed gain by using multiple nodes on very large problems - trying the default tutorial cases icoFoam/cavity and interFoam/damBreak in parallel on two nodes results in dismally slow performance, many times slower than solving locally using a single node.
Is this pretty typical for a slow interconnect like Fast Ethernet?
quinnr is offline   Reply With Quote
Old   August 9, 2006, 02:24
Default Yes, we found the same. -lapto
  #15
Mattijs Janssens
mattijs is on a distinguished road
Yes, we found the same. -laptops have really bad networking. They do support the standard (e.g. 100 Mb/s) but the obtainable throughput is nowhere near that number. -small cases require low latency interconnects.
You can play around with the scheduledTransfer, floatTransfer settings.
Better is to speed up your interconnect. Gigabit ethernet is cheap. Then you can look at some of the higher (than LAM) performance MPI implementations. Lowest latency public domain one is MPI/GAMMA (very intrusive though). A commercial low latency implementation I know is Scali-MPI. OpenMPI can do channel bonding (send through multiple ports at the same time) which helps bandwidth.
Beyond this there are the specialised interconnects. Very good but expensive.
mattijs is offline   Reply With Quote
Old   August 10, 2006, 00:19
Default Thank you for the feedback Mat
  #16
Quinn Reynolds
Thank you for the feedback Mattijs.
I suspected that the latency would be an issue for small cases, I just wasn't sure whether the impact was that severe.
I think as a temporary measure we'll stick to running smaller cases in series or on the dual processor node, and rope in the cluster for very large cases that will need to run for days+.
I'll start budgeting for some better interconnects too
Kind regards,
Quinn
Old   July 5, 2007, 02:30
Default The message says that you have
  #17
Francesco Del Citto
fra76 is on a distinguished road
The message says that you have an error on line "1", so before the part that you posted here.
Your decomposeParDict file should start with:
| \ / O peration | Version: 1.3 |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object decomposeParDict;
Check line 1, and post the whole file if you cannot find the error!
Francesco
fra76 is offline   Reply With Quote
Old   July 5, 2007, 03:02
Default Do you include the following l
  #18
Håkan Nilsson
hani is on a distinguished road
Do you include the following line in your PBS script:
cd $PBS_O_WORKDIR
If not, you will not run your job from where you submit it.
You can also try specifying the whole path to your case instead of just '.' or '..'
Håkan.
hani is offline   Reply With Quote
Old   July 16, 2007, 06:25
Default Hi all, I hope not "cutting"
  #19
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi all,
I hope not "cutting" the previous discussion there ...
I have a problem with my parallel runs.
I save the result every 10 time step (for exemple) and it woks correctly up to there (exept continuity errors 10e-13) then, OF write the result fiels (I think) and then I got this message:
FOAM FATAL ERROR : NO_READ specified for read-constructor of object R of class IOobject
If I change the interval write to 15, the mistake arrive after 15 iterations ...
I forgot something ?, Some one has an idea ?
Thanks for your help.
Cedric
cedric_duprat is offline   Reply With Quote
Old   September 29, 2007, 10:49
Default Hi, I'm struggling with the f
  #20
ville vuorinen
ville is on a distinguished road
I'm struggling with the following problem: in a
parallel computing system a parallel simulation
has to be started from a "login node". However,
I would like to put my case directory on a partition that is "project directory" which
is directly visible to the login node.
1) if I run icoFoam on single processor this works
2) however, if I try to mpirun the same with
mpirun .... it does not work but the following
error occurs:
Cannot read "/home/u2/..../cavity/system/decomposeParDict"
The path in the declaration goes right but
how
should I setup the environment in order to make
OF see the other partition?
Regards,
Ville
ville is offline   Reply With Quote
Running fluent parallel with PBS Jaggu FLUENT 1 June 8, 2011 11:29
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 09:32
Problem in running Parallel mamaly60 OpenFOAM Running, Solving & CFD 1 April 19, 2010 11:11
Problems on running cfx in parallel Nan CFX 1 March 29, 2006 04:10
Postprocessing after running in parallel balakrishnan OpenFOAM Pre-Processing 0 March 11, 2005 11:22
