-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Need help with boundary conditions: open to atmosphere (http://www.cfd-online.com/Forums/openfoam/87082-need-help-boundary-conditions-open-atmosphere.html)
Wolle April 11, 2011 06:51
Hi all,
after trying a lot of different setups, it seems that I need some help with the boundary conditions of my problem. I think posting the entire setup here is much too long, so I'm going to attach the whole zipped case.
The setup is as follows, I attach a picture of that in the end. The case is two dimensional and I have two regions, which gives two meshes. It can be described as a sqare with an annulus in the middle. The annulus is rotating with constant speed and has a fixed temperature of 473K. In the middle of the annulus, there's nothing. The surrounding square is filled with air as fluid, only the bottom is considered a wall, left, right and top are open to atmosphere. The fluid has initially a temperature of 300K and I want air that is sucked into the domain to have 300K too. There is no specific inlet or outlet. The only kinematic component of the case is rotation of the annulus. I implemented this, by simply setting a rotatingWallVelocity in the fluid/U file. No mesh movement or the like.
So far, temperature coupling works very well. Considering velocity and pressure, I've got a lot of different results, depending on the boundary conditions. Some results show nearly stable situations, but have strange distortions every now and then. Some results show even more stable situations, but then the simulation explodes suddenly (20% of the solvers log is taken by the last 0.5% of the time simulated). Some of the boundary conditions I considered to be appropriate give strange results, while others which at first don't seem right, produce better results... I'm stuck with too much different setups that I tried...
So here is, what it should look like: (example for a nearly stable solution, but disturbed every now and then)
http://img192.imageshack.us/img192/2...outletpres.png
Yes, I'm looking for a stable (steady state?) solution, but want to calculate time dependent stuff, so I chose chtMultiRegionFoam as solver. I think, there's nothing wrong with that choice and my problem is only related to boundary conditions...
...to be continued...
Wolle April 11, 2011 07:21
4 Attachment(s)
Okay, just to give an example, here's a summary of the basic setup for the case which I took the screenshot of...
Remarks: My solid is called "GAL" in my case, fluid is named "FLUID_AMB". I left the comments in the case setup files by intention... With respect to the FLUID_AMB/0/U settings of inletOutlet, I want to explain, that this is just an idea and only one of various combinations I tried. Giving well defined velocity BCs seem to produce far more stable results, although I wanted to have zero (or pressure calculated) inlet velocity...
Solver: chtMultiRegionFoam
System settings
Fluid:
system/FLUID_AMB/fvSchemes
ddtSchemes
    default        Euler;
gradSchemes
    default        Gauss linear;
divSchemes
    default        none;
    div(phi,U)      Gauss upwind;
    div(phiU,p)    Gauss linear;
    div(phi,h)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(R)          Gauss linear;
    div((muEff*dev2(grad(U).T()))) Gauss linear;
laplacianSchemes
    default        none;
    laplacian(muEff,U) Gauss linear limited 0.333;
    laplacian((rho*(1|A(U))),p_rgh) Gauss linear limited 0.333;
    laplacian(alphaEff,h) Gauss linear limited 0.333;
    laplacian(DkEff,k) Gauss linear limited 0.333;
    laplacian(DepsilonEff,epsilon) Gauss linear limited 0.333;
    laplacian(DREff,R) Gauss linear limited 0.333;
interpolationSchemes
    default        linear;
snGradSchemes
    default        limited 0.333;
fluxRequired
    default        no;
    p_rgh;
system/FLUID_AMB/fvSolution
solvers
    rho
        solver          PCG
        preconditioner  DIC;
        tolerance      1e-7;
        relTol          0;
    p_rgh
        solver          GAMG;
        tolerance        1e-7;
        relTol          0.01;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels      1;
    p_rghFinal
        solver          GAMG;
        tolerance        1e-7;
        relTol          0;
        mergeLevels      1;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance        1e-7;
        relTol          0;
    h
        solver          PBiCG;
        tolerance        1e-7;
        relTol          0.1;
    hFinal
        solver          PBiCG;
        tolerance        1e-7;
        relTol          0;
    k
        solver          PBiCG;
        tolerance        1e-7;
        relTol          0;
    epsilon
        solver          PBiCG;
        tolerance        1e-7;
        relTol          0;
    R
        solver          PBiCG;
        tolerance        1e-7;
        relTol          0;
PISO
    momentumPredictor    off;
    nOuterCorrectors    1;
    nCorrectors          2;
    nNonOrthogonalCorrectors 1;
    pRefPoint            (-0.081 -0.0257 8.01);
    pRefValue            1e5;
PIMPLE
    momentumPredictor  on;
    nCorrectors        2;
    nNonOrthogonalCorrectors 0;
relaxationFactors
    h              1;
    U              1;
Solid
system/GAL/fvSchemes
ddtSchemes
    default        Euler;
gradSchemes
divSchemes
    default        none;
laplacianSchemes
    default        none;
    laplacian(K,T)  Gauss linear limited 0.333;
    default        linear;
snGradSchemes
fluxRequired
    default        no;
system/GAL/fvSolution
solvers
    T
        solver          PCG;
        preconditioner  DIC;
        tolerance        1E-06;
        relTol          0;
PISO
PIMPLE
Constant settings
Fluid
constant/FLUID_AMB/g
dimensions      [0 1 -2 0 0 0 0];
value          (0 -9.81 0);
constant/FLUID_AMB/RASProperties
RASModel laminar;
turbulence      on;
printCoeffs    on;
constant/FLUID_AMB/thermophysicalProperties
thermoType      hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>;
mixture        air 1 28.9 1000 0 1.8e-05 0.7;
constant/FLUID_AMB/turbulenceProperties
simulationType  laminar;
Boundary conditions - Fluid
0/FLUID_AMB/epsilon
dimensions      [0 2 -3 0 0 0 0];
internalField  uniform 0.001;
boundaryField
    FLUID_AMB_to_GAL
        type            compressible::epsilonWallFunction;
        value          uniform 0.001;
    FLUID_AMB_down
    FLUID_AMB_up
        type            inletOutlet;
        inletValue      uniform 0.001;
    FLUID_AMB_left
        type            inletOutlet;
    FLUID_AMB_right
        type            inletOutlet;
0/FLUID_AMB/k
dimensions      [0 2 -2 0 0 0 0];
boundaryField
    FLUID_AMB_to_GAL
                type            compressible::kqRWallFunction;
    FLUID_AMB_down
    FLUID_AMB_up
        type            inletOutlet;
    FLUID_AMB_left
        type            inletOutlet;
    FLUID_AMB_right
        type            inletOutlet;
0/FLUID_AMB/p
dimensions      [1 -1 -2 0 0 0 0];
internalField  uniform 1e5;
boundaryField
    FLUID_AMB_to_GAL
        type            calculated;
        value          uniform 1e5;
    FLUID_AMB_down
        type            calculated;
        value          uniform 1e5;
    FLUID_AMB_up
        type            calculated;
        value          uniform 1e5;
    FLUID_AMB_left
        type            calculated;
        value          uniform 1e5;
    FLUID_AMB_right
        type            calculated;
        value          uniform 1e5;
0/FLUID_AMB/p_rgh
boundaryField
    FLUID_AMB_to_GAL
        type            buoyantPressure;
        value          uniform 1e5;
    FLUID_AMB_down
        value          uniform 1e5;
    FLUID_AMB_up
        type        outletInlet;
        outletValue    1e5;
        value        1e5;
// would lead to adiabatic bounday?
        type        waveTransmissive;
        psi        psi;
        gamma        1;
        value        uniform 1e5;
        type        fixedValue;
        value        uniform 100017.10;
        type        totalPressure;
        p0        uniform 1e5;    // Total pressure
        U        U;        // Name of the velocity field
        phi        phi;        // Name of the flux transporting the field
        rho        rho;        // Name of the density field used to normalise the mass flux if neccessary
        psi        none;        // Name of the compressibility field used to calculate the wave speed
        gamma        1;        // Heat capacity ratio
        value        uniform 0;
    FLUID_AMB_left
        type        outletInlet;
        outletValue    uniform 1e5;
        value        uniform 1e5;
        psi        psi;
        gamma        1;
        value        uniform 1e5;
    FLUID_AMB_right
        type        outletInlet;
        value        uniform 1e5;
        psi        psi;
        gamma        1;
        value        uniform 1e5;
0/FLUID_AMB/T
dimensions      [0 0 0 1 0 0 0];
internalField  uniform 300;
boundaryField
    FLUID_AMB_to_GAL
//        type            compressible::turbulentTemperatureCoupledBaffle;
        type            solidWallMixedTemperatureCoupled;
        neighbourFieldName T;
        K              K;
        value          uniform 300;
    FLUID_AMB_down
        type            zeroGradient;
        value        uniform 300;
    FLUID_AMB_up
        type            inletOutlet;
        inletValue    uniform 300;
        value          uniform 300;
    FLUID_AMB_left
        type            inletOutlet;
        value          uniform 300;
    FLUID_AMB_right
        type            inletOutlet;
        value          uniform 300;
0/FLUID_AMB/U
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0 0.01 0);
boundaryField
    FLUID_AMB_to_GAL
        type        rotatingWallVelocity;
        origin        (0 0 0);
        axis        (0 0 1);
        omega        41.887902053;
    FLUID_AMB_down
        type            fixedValue;
        value          uniform ( 0 0 0 );
    FLUID_AMB_up
        type        fluxCorrectedVelocity;
        phi        phi;
        rho        rho;
        type            pressureInletOutletVelocity;
    FLUID_AMB_left
        type        inletOutlet;
        inletValue    uniform ( 0.05 0 0 );
        value        uniform ( 0.05 0 0 );
    FLUID_AMB_right
        type        inletOutlet;
        inletValue    uniform ( -0.05 0 0 );
        value        uniform ( -0.05 0 0 );
Boundary conditions - Solid
0/GAL/cp
dimensions      [0 2 -2 -1 0 0 0];
internalField  uniform 450;
boundaryField
//        type            calculated;
        type            zeroGradient;
        value          uniform 450;
0/GAL/K
dimensions      [1 1 -3 -1 0 0 0];
internalField  uniform 80;
boundaryField
//        type            calculated;
          type            zeroGradient;
          value          uniform 80;
0/GAL/rho
dimensions      [1 -3 0 0 0 0 0];
internalField  uniform 8000;
boundaryField
          type            calculated;
          value          uniform 8000;
0/GAL/T
internalField  uniform 473;
boundaryField
    GAL_to_FLUID_AMB
        K            K;
        value            uniform 473;
    GAL_inside
        type            fixedValue;
        value            uniform 473;
How to unpack?
Well, as the upload file size is limited per file, I had to split the archive...
You can easily unpack with this single command line:
$ cat example.tar.gz-a* | tar zxvf -
I had to rename the files to *.txt... which is of no further meaning to that command...
The case has a ./Allclean script that should clean up everything and a ./Allrun script to run the case.
Note, that the log.blockMesh.* files should not be removed, as the correct settings in constant/*/polyMesh/boundary would have to be set manually afterwards! That's why I included those files (and logfiles) into the package...
Wolle April 11, 2011 07:32
So far for now. For those who want to give it a test run, just try the above case files (BCs might slightly differ, as I tried many combinations).
What I tried so far, are different bc setups mostly for U and p_rgh of the fluid.
What should be most appropriate for U at left, right and top boundary, is in my opinion pressureInletOutletVelocity although I'm not sure, whether this would "amplify" a given state of the system and by this lead to instability. The header file for this velocity boundary condition says: "Velocity inlet/outlet boundary condition patches for where the pressure is specified. Zero-gradient is applied for outflow (as defined by the flux) and for inflow the velocity is obtained from the patch-face normal component of the internal-cell value." Sounds nice... but I didn't manage to set it up with a good BC for pressure by now.
Thus I think I need to specify p and/or p_rgh. I found this posting on that subject:
http://www.cfd-online.com/Forums/ope...tml#post262838
Now... leaving p all calculated and setting left, right and top BC fpr p_rgh to uniformDensityHydrostaticPressure doesn't work... I get very low temperatures and stuff. Maybe setting p to calculated is wrong with that boundary condition? In the above mentioned thread, there's the advice to set pd=0 (in OF 1.5). How to apply this in my case and with respect to OF 1.7?
Cheers & Thanks for reading so far!
Wolle
P.S.: I hope it's not "too much", but posting less might have lead to further information requests.... so I simply decided to post it all together... :o
