Inlet and Outlet
Hi All
I am trying to setup a simple case with an Inlet and an Outlet. I am used to WinAir, where you only input a Volumetric Flow (m3/s) and a directional Vector. I am reviewing the Derived Patch Field Types...but I am confused about which one to use. Could anyone help me on that? Thanks Another question I have is about the relationship between solvers and the different Patch Field Types.( I am using buoyanBoussinesqSimpleFoam, and the other steady state solver dealing with heat Transfer for buoyancy driven flows...) Can I use anyone of the patch fields described in page U-133 ? or are they linked to a precise solver? Thanks Luis Blanes |
Errors regarding Inlet and Outlet
Hello all
I tried to run a simulation with the following values at the U/0 directory boundaryField { warm { type fixedValue; value uniform (0 0 0); } cool { type fixedValue; value uniform (0 0 0); } defaultFaces { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 -1); } outlet { type fixedValue; value uniform (0 0 1); And I got that error. Can somebody please help me? Thanks Can I input just two velocities in a patch just typing that in the U/0 directory?? Can the velocity vector point outside the domain?? Thanks Starting time loop Time = 0.1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00451649, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.88538e-17, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::DILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::DILUPreconditioner::DILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::lduMatrix::preconditioner::addasymMatrixCons tructorToTable<Foam::DILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #8 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libfiniteVolume.so" #9 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #10 __libc_start_main in "/lib/libc.so.6" #11 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" Floating point exception ; |
Try to use zeroGradient for your outflow. Is the direction of the velocity in your inlet ok?
Yes, the direction in the Inlet makes no sense. I guess that you only need to input a velocity in the inlet and zeroGradient in the outlet. Thanks |
Inlet velocity is ok....
I have checked the case again...
I use buoyantBoussinesqSimpleFoam Can anyone tell me how to input a simple Inlet and Outlet in using heatTransfer solvers? U at inlet is ok (0 0 -1) as it is pointing inside the domain (can I use negative numbers?) Thanks in advance ----------------------------------------------------- boundary file 5 ( warm { type wall; nFaces 390; startFace 90580; } cool { type wall; nFaces 390; startFace 90970; } inlet { type patch; nFaces 1; startFace 91360; } outlet { type patch; nFaces 1; startFace 91361; } defaultFaces { type wall; nFaces 5270; startFace 91362; } ---------------------------------------------------- U/0 dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { warm { type fixedValue; value uniform (0 0 0); } cool { type fixedValue; value uniform (0 0 0); } defaultFaces { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 -1); } outlet { type zeroGradient; { } ---------------------------------------------------- p/0 dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { warm { type buoyantPressure; rho rhok; value uniform 0; } cool { type buoyantPressure; rho rhok; value uniform 0; } defaultFaces { type buoyantPressure; rho rhok; value uniform 0; } inlet { type buoyantPressure; rho rhok; value uniform 0; } outlet { type buoyantPressure; rho rhok; value uniform 0; } } |
Hi lmblanes
Just wondering a little about your pressure setup. You might try keeping the outlet/internalField at uniform 0 and setting the rest to zeroGradient. My experience is only really with simpleFoam, so I hope this helps. Also, yes you can use negative numbers for velocity as long as you're sure its in the right direction. Dom |
Thanks!
I have seen lots of cases where there is an Inlet and the "Outlet" is just a free pressure boundary... What do you mean with "in the right direction"? Is there some rule? I wonder if I can do something like this ________________ I I I I Inlet(1m3/s) ---> Outlet(0.9 m3/s) ---> I I I I I Opening to atmosphere I_______________ I Thanks |
