wall functions and boundary conditions in OF 1.7.1
Old   May 4, 2011, 20:27
Default wall functions and boundary conditions in OF 1.7.1
cristobal albarracin
cristobal is on a distinguished road
Hi everyone,
I am running a case of flow past an airfoil using simleFoam and the kOmegaSST turbulence model. I have a y+ of less than 1 everywhere. When I use wall functions it runs ok, but it doesn't quite reach the free stream value of k that I specified in the boundary conditions. When I use the FixedValue condition at the wall, the boundary layer gets way too thick. I am not sure what the value of omega should be at the wall, in theory it should be 0, because k=0, but when I specify that value the solver crashes. I tried a very small but non-zero value and it runs, but with the BL grows too thick.
I am not sure if using wall functions is justified if y+ is less than 1, can anyone give me some advice?
Cheers.
cristobal is offline   Reply With Quote
Old   May 5, 2011, 10:50
Default Wall functions
Arnout
The King is on a distinguished road
For turbulance, there are two methods close to the wall. Wall functions for y+ > 30 or integrating to the wall. See
http://www.cfd-online.com/Wiki/Near-...k-omega_models
Good luck!
The King is offline   Reply With Quote
Old   May 6, 2011, 04:10
romant's Avatar
Roman Thiele
romant is on a distinguished road
if you wanna run this case in low Re approach, consider the following link http://www.cfd-online.com/Forums/ope...omega-sst.html it will give you the right boundary conditions and some suggestions on how to use the OpenFOAM kOmegaSST model in a low Re (y+<1)
~roman
romant is offline   Reply With Quote
wall boundary conditions, wall functions
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
