pythonFlu installation error in Ubuntu 10.10
Hi there,
I am getting following error while installing pythonFlu (pythonflu171_8.0-1_maverick_i386.deb) dhastha@Dhastha:~$ sudo dpkg --install pythonflu171_8.0-1_maverick_i386.deb (Reading database ... 188750 files and directories currently installed.) Unpacking pythonflu171 (from pythonflu171_8.0-1_maverick_i386.deb) ... dpkg-deb (subprocess): short read on buffer copy for failed to write to pipe in copy dpkg-deb: subprocess paste returned error exit status 2 dpkg: error processing pythonflu171_8.0-1_maverick_i386.deb (--install): short read on buffer copy for backend dpkg-deb during `./usr/local/lib/python2.6/dist-packages/Foam/transportModels/_transportModels_.so' Errors were encountered while processing: pythonflu171_8.0-1_maverick_i386.deb |
I have just bumped on your post by accident. What for to wait so long for someone's answer if there is an official pythonFlu bug tracker? About the question, have you checked whether the "pythonflu171_8.0-1_maverick_i386.deb" package you downloaded is whole or broken? Run md5sum Linux utility to verify that it is equal to "d62a707aec5449826a6a0c37ac21a7fd". Best regards, Alexey |
You are right. The package which I downloaded was broken. I downloaded again fresh pythonflu1.7 and installed successfully
HI !
I am new to OpenFoam. I need check the my PC : 32bit or 64bit and so I have a "pythonflu" package conformable . I checked whether the "pythonflu171_8.1-Elvis-1_maverick_i386.deb" package I downloaded. However, it appeared error. Plz, can you help me ! thanks ! :) |
Hi phuchuynh
If you want to check your PC is 32 bit or 64 bit, you just type the following command in terminal Code:
lscpu I have some question for you. What Ubuntu version your are using? What are the error your are getting? Please post the error here |
Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit CPU(s): 2 . I am using Ubuntu version 10.10. I downloaded packages "pythonflu171_8.1-Elvis-1_maverick_amd64.deb" and "pythonflu171_8.1-Elvis-1_maverick_i386.deb" .So, I will install package ? Code:
root@phuc:~# dpkg --install pythonflu171_8.1-Elvis-1_maverick_amd64.deb Sorry, because It is long Thanks ! |
Hi Phuchuynh,
I guess you have run the installation procedure for pythonFlu package more then once. I confirm, that this is a bug in pythonFlu installation and we are going to fix it in next release (in about one month). For now, we suggest the following workaround.
Hope this will help, Alexey |
Same problem with natty and same workaround.
You just have to change python2.6 with python2.7 in the procedure above Thanks for the tip :) |
