June 3, 2011, 14:35
Problems about compiling OF1.5.x on Bluegene/P
Yong Wang
Hi everyone,
I am compiling OF1.5.x on a supercomputer Bluegene/P with gcc 4.3.2.
I have compiled libraries (lib/linuxPPC64GccDPOpt) successfully but failed to build any executive file (applications/bin/linuxPPC64GccDPOpt).
Some errors are given as follow. It can not find the libraries. But I am sure the path of the libraries are right.
Does anyone know the reason? Any message is welcome.
PHP Code:
+ cd .
+ cd wmake/src
+ make
make: Nothing to be done for `all'.
+ cd /home/yongwang/OpenFOAM/ThirdParty-1.5.x-32
+ ./Allwmake
+ '[' -n /soft/apps/current/gcc-4.3.2/comm/default/bin/mpicc ']'
+ export CC=/soft/apps/current/gcc-4.3.2/comm/default/bin/mpicc
+ CC=/soft/apps/current/gcc-4.3.2/comm/default/bin/mpicc
+ '[' -n /soft/apps/current/gcc-4.3.2/comm/default/bin/mpicxx ']'
+ export CXX=/soft/apps/current/gcc-4.3.2/comm/default/bin/mpicxx
+ CXX=/soft/apps/current/gcc-4.3.2/comm/default/bin/mpicxx
+ '[' -n -fPIC ']'
+ export CFLAGS=-fPIC
+ CFLAGS=-fPIC
+ '[' -n -fPIC ']'
+ export CXXFLAGS=-fPIC
+ CXXFLAGS=-fPIC
+ '[' -n '' ']'
+ wmake libso zlib-1.2.3
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libz.so' is up to date.
+ cd malloc
+ ./Allwmake
+ wmake libso hoard
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libhoard.so' is up to date.
+ wmake libo fbsdmalloc
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libfbsdmalloc.o' is up to date.
+ case "$WM_MPLIB" in
+ cd metis-5.0pre2
+ wmake libso GKlib
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libGKlib.so' is up to date.
+ wmake libso libmetis
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libmetis.so' is up to date.
+ '[' -d /opt/mpi ']'
+ wmake libso ParMGridGen-1.0/MGridGen/IMlib
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libIMlib.so' is up to date.
+ wmake libso ParMGridGen-1.0/MGridGen/Lib
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libMGridGen.so' is up to date.
+ cd src
+ ./Allwmake
+ cd OpenFOAM
+ wmakeLnInclude .
+ cd Pstream
+ ./Allwmake
+ wmake libso dummy
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/dummy/libPstream.so' is up to date.
+ set +x
Note: ignore spurious warnings about missing mpicxx.h headers
+ WM_OPTIONS=linuxPPC64GccDPOptMPI
+ wmake libso mpi
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/mpi/libPstream.so' is up to date.
+ wmake libo OSspecific/Unix
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libOSspecific.o' is up to date.
+ wmake libso OpenFOAM
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libOpenFOAM.so' is up to date.
+ wmake libso lagrangian/basic
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/liblagrangian.so' is up to date.
+ wmake libso triSurface
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libtriSurface.so' is up to date.
+ wmake libso edgeMesh
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libedgeMesh.so' is up to date.
+ wmake libso meshTools
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libmeshTools.so' is up to date.
+ wmake libso finiteVolume
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libfiniteVolume.so' is up to date.
+ cd decompositionAgglomeration
+ ./Allwmake
+ wmake libso decompositionMethods
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libdecompositionMethods.so' is up to date.
+ '[' -d /home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/mpi ']'
+ wmake libso parMetisDecomp
/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/gnu-linux/lib/gcc/powerpc-bgp-linux/4.1.2/../../../../powerpc-bgp-linux/bin/ld: cannot find -lmetis-parmetis
collect2: ld returned 1 exit status
make: *** [/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/mpi/libparMetisDecompositionMethod.so] Error 1
+ wmake libso MGridGenGamgAgglomeration
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libMGridGenGAMGAgglomeration.so' is up to date.
+ wmake libso sampling
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libsampling.so' is up to date.
+ wmake libso dynamicMesh
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libdynamicMesh.so' is up to date.
+ wmake libso dynamicFvMesh
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libdynamicFvMesh.so' is up to date.
+ wmake libso topoChangerFvMesh
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libtopoChangerFvMesh.so' is up to date.
+ wmake libso fvMotionSolver
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libfvMotionSolvers.so' is up to date.
+ wmake libso engine
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libengine.so' is up to date.
+ wmake libso ODE
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libODE.so' is up to date.
+ wmake libso randomProcesses
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/librandomProcesses.so' is up to date.
+ cd thermophysicalModels
+ ./Allwmake
+ wmake libso specie
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libspecie.so' is up to date.
+ wmake libso thermophysicalFunctions
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libthermophysicalFunctions.so' is up to date.
+ wmake libso liquids
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libliquids.so' is up to date.
+ wmake libso liquidMixture
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libliquidMixture.so' is up to date.
+ wmake libso solids
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libsolids.so' is up to date.
+ wmake libso solidMixture
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libsolidMixture.so' is up to date.
+ wmake libso basic
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libbasicThermophysicalModels.so' is up to date.
+ wmake libso combustion
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libcombustionThermophysicalModels.so' is up to date.
+ wmake libso laminarFlameSpeed
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/liblaminarFlameSpeedModels.so' is up to date.
+ wmake libso chemistryModel
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libchemistryModel.so' is up to date.
+ wmake libso pdfs
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libpdf.so' is up to date.
+ wmake libso radiation
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libradiation.so' is up to date.
+ wmake libso barotropicCompressibilityModel
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libbarotropicCompressibilityModel.so' is up to date.
+ cd transportModels
+ ./Allwmake
+ wmake libso incompressible
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libincompressibleTransportModels.so' is up to date.
+ wmake libso interfaceProperties
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libinterfaceProperties.so' is up to date.
+ cd turbulenceModels
+ ./Allwmake
+ cd RAS
+ ./Allwmake
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libincompressibleRASModels.so' is up to date.
+ wmake libso compressible
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libcompressibleRASModels.so' is up to date.
+ cd LES
+ ./Allwmake
+ wmake libso LESfilters
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libLESfilters.so' is up to date.
+ wmakeLnInclude incompressible
+ wmake libso LESdeltas
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libLESdeltas.so' is up to date.
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libincompressibleLESModels.so' is up to date.
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libcompressibleLESModels.so' is up to date.
+ cd lagrangian
+ ./Allwmake
+ wmake libso basic
+ wmake libso solidParticle
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libsolidParticle.so' is up to date.
+ wmake libso intermediate
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/liblagrangianIntermediate.so' is up to date.
+ wmake libso dieselSpray
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libdieselSpray.so' is up to date.
+ cd molecularDynamics
+ wmake libso potential
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libpotential.so' is up to date.
+ wmake libso molecule
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libmolecule.so' is up to date.
+ cd postProcessing
+ ./Allwmake
+ wmake libo postCalc
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/postCalc.o' is up to date.
+ wmake libso forces
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libforces.so' is up to date.
+ wmake libso fieldAverage
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libfieldAverage.so' is up to date.
+ wmake libso foamCalcFunctions
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libfoamCalcFunctions.so' is up to date.
+ cd conversion
+ ./Allwmake
+ wmake libso
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libconversion.so' is up to date.
+ wmake libso autoMesh
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/libautoMesh.so' is up to date.
+ wmake libso errorEstimation
'/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt/liberrorEstimation.so' is up to date.
+ cd applications
+ ./Allwmake
+ cd solvers
+ wmake all
make[1]: Entering directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic'
make[2]: Entering directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic/laplacianFoam'
mpicxx -DlinuxPPC64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OpenFOAM/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OSspecific/Unix/lnInclude -fPIC -I/home/yongwang/OpenFOAM/bgp/flex/include -I/home/yongwang/OpenFOAM/bgp/zlib/include -L/home/yongwang/OpenFOAM/bgp/flex/lib -L/home/yongwang/OpenFOAM/bgp/zlib/lib Make/linuxPPC64GccDPOpt/laplacianFoam.o -L/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/laplacianFoam
/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/gnu-linux/lib/gcc/powerpc-bgp-linux/4.1.2/../../../../powerpc-bgp-linux/bin/ld: cannot find -lfiniteVolume
make[2]: *** [/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/laplacianFoam] Error 1
make[2]: Leaving directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic/laplacianFoam'
make[1]: *** [laplacianFoam] Error 2
make[2]: Entering directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic/potentialFoam'
mpicxx -DlinuxPPC64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OpenFOAM/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OSspecific/Unix/lnInclude -fPIC -I/home/yongwang/OpenFOAM/bgp/flex/include -I/home/yongwang/OpenFOAM/bgp/zlib/include -L/home/yongwang/OpenFOAM/bgp/flex/lib -L/home/yongwang/OpenFOAM/bgp/zlib/lib Make/linuxPPC64GccDPOpt/potentialFoam.o -L/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/potentialFoam
make[2]: *** [/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/potentialFoam] Error 1
make[2]: Leaving directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic/potentialFoam'
make[1]: *** [potentialFoam] Error 2
make[2]: Entering directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic/scalarTransportFoam'
mpicxx -DlinuxPPC64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OpenFOAM/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OSspecific/Unix/lnInclude -fPIC -I/home/yongwang/OpenFOAM/bgp/flex/include -I/home/yongwang/OpenFOAM/bgp/zlib/include -L/home/yongwang/OpenFOAM/bgp/flex/lib -L/home/yongwang/OpenFOAM/bgp/zlib/lib Make/linuxPPC64GccDPOpt/scalarTransportFoam.o -L/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/scalarTransportFoam
make[2]: *** [/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/scalarTransportFoam] Error 1
make[2]: Leaving directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic/scalarTransportFoam'
make[1]: *** [scalarTransportFoam] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/basic'
make: *** [basic] Error 2
make[1]: Entering directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/combustion'
make[2]: Entering directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/combustion/coldEngineFoam'
mpicxx -DlinuxPPC64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I../engineFoam -I../XiFoam -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/engine/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/finiteVolume/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/thermophysicalModels/specie/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/thermophysicalModels/basic/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/thermophysicalModels/combustion/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/turbulenceModels/RAS/compressible/lnInclude -IlnInclude -I. -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OpenFOAM/lnInclude -I/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/src/OSspecific/Unix/lnInclude -fPIC -I/home/yongwang/OpenFOAM/bgp/flex/include -I/home/yongwang/OpenFOAM/bgp/zlib/include -L/home/yongwang/OpenFOAM/bgp/flex/lib -L/home/yongwang/OpenFOAM/bgp/zlib/lib Make/linuxPPC64GccDPOpt/coldEngineFoam.o -L/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/lib/linuxPPC64GccDPOpt \
-lengine -lfiniteVolume -lcompressibleRASModels -lbasicThermophysicalModels -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/coldEngineFoam
/bgsys/drivers/V1R4M2_200_2010-100508P/ppc/gnu-linux/lib/gcc/powerpc-bgp-linux/4.1.2/../../../../powerpc-bgp-linux/bin/ld: cannot find -lengine
make[2]: *** [/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/bin/linuxPPC64GccDPOpt/coldEngineFoam] Error 1
make[2]: Leaving directory `/gpfs/home/yongwang/OpenFOAM/OpenFOAM-1.5.x-32/applications/solvers/combustion/coldEngineFoam'
make[1]: *** [coldEngineFoam] Error 2
