April 18, 2011, 06:15 |
K Epsilon convergance issue
Hi OpenFoamers,
I am having some trouble with K Epsilon when using PisoFOAM, I am initialising in SimpleFOAM and taking the final time step obtained from SimpleFOAM to be used as the 0 file for PisoFOAM. The flow type is high Reynolds number flow over a cylinder within a control volume. The flow properly initialises in simpleFOAM and converges as expcted. However after 10,000 iterations in pisoFoam there is little difference if any in the flow structure, a steady-state results appears to be gained. I am using an Euler scheme and have ran for 10 seconds. There is sort of instantaneous convergance. The expected flow structure should be completely turbulent, with eddies being shed alternately from the cylinder, however a pointed "tail" remains in the cylinder wake. I have ran a similar model in LES with no complications, thus justifing the mesh is of a high standard. Has anyone else had this problem, if so, how did you resolve it? My initial/boundary conditions are below. internal Field U - (1.461, 0, 0) p - 0 epsilon - 0.024 k - 0.020491 nut - 0 inlet U - fixed value (1.461, 0, 0) p - zerogradient k - fixed value 0.020491 epsilon - fixed value 0.024 nut - calculated 0 Cylinder U - fixed value - (0,0,0) p - zerogradient k - kqRWallFunction (value 0.020491) epsilon - epsilonWallFunction (value 0.024) nut- nutWallFunction (value 0) outlet U - fixedValue 1.461, 0, 0) p - fixedVlaue 0 k - zerogradient epsilon - zerogradinet nut - calculated (value 0) Cheers Ollie |
April 18, 2011, 08:11 |
#2 | |
maddalena
Rep Power: 23 |
outlet U - zeroGradient or inletOutlet p - fixedVlaue 0 k - zerogradient epsilon - zerogradinet nut - calculated (value 0) |
April 18, 2011, 08:28 |
Hi maddalena,
Firstly thanks for your quick reply. I have tried what you have suggested already, I have tried changing the boundary conditions around for a while, and the result is still the same. Could it be the solver pisoFoam, its looks like pisoFoam is creating a solution which looks like a statistical average, instead of a transient solution ? regards Ollie |
k-epsilon, les. rans |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
How to get reference to k and epsilon in the epsEqn and kEqn | cfd_explorer | OpenFOAM Programming & Development | 0 | March 10, 2011 10:16 |
How to get reference to k and epsilon in the epsEqn and kEqn | cfd_explorer | OpenFOAM | 0 | March 10, 2011 09:58 |
Compressible epsilon blows up | swahono | OpenFOAM | 10 | November 26, 2010 05:38 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
