-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Solver for Incompressible flow with heat transfer using LES (http://www.cfd-online.com/Forums/openfoam/87655-solver-incompressible-flow-heat-transfer-using-les.html)
Tarak April 26, 2011 00:13
Hii,
can someone suggest me a solver in OpenFOAM suitable for Incompressible flow with heat transfer with LES. I don't seem to find a solver having to fit this combination exactly.
Thanks,
Tarak
vkrastev April 26, 2011 08:40
Originally Posted by Tarak (Post 305045)
Hii,
Thanks,
Tarak
If you have an updated 1.7.x version of OpenFOAM, then the chtMultiRegionFoam solver can do this kind of job. Alternatively, if you have the 1.7.1 version you can download the add-ons for the handling of incompressible flows with heat transfer from the git repository of the 1.7.x version and then compile them by yourself (it should be quite easy). The link for doing this is here https://github.com/OpenCFD/OpenFOAM-.../master?page=6 (the add-ons in question are contained in the 14-15/10/2010 updates)
Hope this helps
V.
palmerlee December 20, 2013 09:43
Hi, V.
I have the same question. But for some reason, I have to use 2.0.1 version of OpenFOAM. You got any suggestions? Thank you!
palmerlee
