save the last timestep
Like Tree2Likes
  • 2 Post By mabinty
Old   April 27, 2011, 18:44
Default save the last timestep
pit
pit is on a distinguished road
Hi, I have only a short question. Is it possible to save the timestep before foam shut down? I have a long calculation with adjustable timestep and long write intervals. The 'purgeWrite' option doesen't work well for me. Thanks and best regards
pit is offline   Reply With Quote
Old   April 27, 2011, 19:06
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
When does your simulation end? If you know how long you are going to run it, then you just need to match your interval in such a way you get an integer number of steps. Otherwise you need to add
runTime.writeNow()
to the solver, just before the
return 0;
statment ending the simulation.
mturcios777 is offline   Reply With Quote
Old   April 28, 2011, 23:19
Tony
tonyuprm is on a distinguished road
In your system/controlDict you can use:
stopAt writeNow;
This will stop and write your fields. Hope this helps.
tonyuprm is offline   Reply With Quote
Old   November 28, 2011, 09:24
Aram Amouzandeh
mabinty is on a distinguished road
dear all!
i have to stop my simulation and write the current time step after a pre-specified ClockTime -> clockTimeLimit. For this task I used the runTime.writeAndEnd() function in the main while-loop of the solver:
while (runTime.run())
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    if(runTime.elapsedClockTime() >= clockTimeLimit)
            Info<< "  Time limit reached." << nl
                  << "  Stop simulation and write current time step."
                  << nl << endl;
        runTime.writeAndEnd();
The code works in serial but causes problem in parallel: at the moment the runTime.writeAndEnd() is executed the solver hangs and does nothing, no output in the log-file.
Does somebody have an idea what is going wrong here?
Thanks in advance!
Cheers,
Aram
mabinty is offline   Reply With Quote
Old   November 28, 2011, 13:18
Aram Amouzandeh
hi!
i changed the code and now it seems to work in parallel:
    scalar clockTime = runTime.elapsedClockTime();
    reduce(clockTime, sumOp<scalar>());
    if(clockTime/Pstream::nProcs() >= clockTimeLimit)
            Info<< "  CPU time limit " << clockTimeLimit << " s reached." << nl
                 << nl << endl;
cheers,
aram
Restart 2-way FSI with different timestep? Lance CFX 10 April 17, 2013 00:37
Adequate timestep selection for multidomain problem gerardosrez CFX 6 November 28, 2010 17:50
Use of Timestep in obtaining solution. hagupta CFX 7 February 28, 2006 13:14
Timestep selection Jindra Kosprdova CFX 9 April 28, 2005 06:41
timestep in transinet simulations caty CFX 1 April 18, 2005 19:54
