May 3, 2011, 11:13 |
Troubles with "stitchMesh"
sirLentschi
Rep Power: 15 |
Hello everyone,
first I extended my single-channel-mesh (of a pump) "svwg0" with "transformPoints -yawPitchRoll "("16 0 0)"" (=16°-rotation around the z-axis) and "mergeMeshes . svwg0 . svwg16" to get a 2-channel-mesh. Then I performed "stitchMesh" with and without the flag "-perfect" and got two different errors (see log files in the appendix). Does anyone know, how I can reduce the tolerance to 1e-06 for matching all the points? And what does "cannot determine best atan point" mean?? Thanks in advance. Regards |
May 4, 2011, 06:58 |
Steven van Haren
Rep Power: 15 |
There is an option -toleranceDict. I don't know how it works but you can play around with it.
However, my advice would be to try to get the points within the standard tolerance. Maybe try mirrorMesh? Is this possible with your geometry? |
May 4, 2011, 11:05 |
sirLentschi
Rep Power: 15 |
Thank you for your answer,but there is no option -toleranceDict!
I cannot use "mirrorMesh", because I need to rotate my mesh! Regards |
May 4, 2011, 11:46 |
Steven van Haren
Rep Power: 15 |
mmm, ok option maybe only avaliable in 1.7.1
In that case I don't have any tips anymore, sorry |
May 5, 2011, 05:16 |
sirLentschi
Rep Power: 15 |
oh,no problem - and thank you for your answer!
I am going to take a complete geometry from CFX, so I do not need merge- and stitchMesh any more. I hope this works!! Regards |
August 11, 2011, 06:59 |
Suhas
Rep Power: 14 |
hi stevenvanharen,
will you please tell me where is this toleranceDict file is in OF 1.7.1? I can not able to find its location. and if you know how to use it, then please give some comments? and is it possible for two patches with equal surface area but one with hexahedra and another with polyhedra mesh to stitch together by any other method in OF 1.7.1 (I tried stitchMesh, but after using this command then also it is showing some faces on that patch). thank you. |
August 11, 2011, 08:22 |
Steven van Haren
Rep Power: 15 |
yes, you can stitch polyhydral with hexahedral, as long as the interface is conformal. This will be quite a strange situation though. Is your interface conformal?
I also couldn't find an example for the toleranceDict myself, so you have to play around with it to see how it works |
August 12, 2011, 04:50 |
Suhas
Rep Power: 14 |
Thank you for replying,
As you said i am able to stitch the hexahedral and polyhedral patches by adjusting some tolerance factor from toleranceDict file. I will write detailed report on this after coming from holidays. thanks again. Regards Suhas |
October 26, 2011, 16:35 |
#9 |
Ralph Moolenaar
Rep Power: 15 |
Hello Suhas,
I'm looking forward to your report! Regards, Ralph
CFD for marine applications? Go to http://www.marinecfd.com/ and join the OF Ship Hydromechanics Group: http://www.cfd-online.com/Forums/gro...mechanics.html |
October 27, 2011, 05:53 |
#10 |
supercommandodhruv
Rep Power: 14 |
http://www.cfd-online.com/Forums/ope...tml#post329665
Take a look here, may be you can find something |
October 27, 2011, 06:01 |
#11 |
Ralph Moolenaar
Rep Power: 15 |
Hi Dhruv,
I already read that post but was looking forward to the findings of Suhas. I tried to stitch to meshes; merging went fine but the stitiching was more difficult. I tried both -perfect and -partial flags, the toleranceDict, etc and I was hoping that Suhas would give me more insight in the toleranceDict. If not I'll post my case over here Ralph
Display Modes | |
Interface troubles | Samu | CFX | 2 | December 8, 2009 03:38 |
setup troubles | maxim | FloEFD, FloWorks & FloTHERM | 0 | March 4, 2009 10:46 |
3d VOF troubles... | Mac | FLUENT | 0 | March 12, 2007 09:41 |
some video troubles... | giosue | Siemens | 2 | February 19, 2003 11:03 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
