May 4, 2011, 08:05 |
Rotor stator interaction LES simulation
Thomas Lloyd
Rep Power: 14 |
Hi all,
I want to conduct a LES simulation of a ducted propeller using sliding mesh. I am running OF 1.7.1. Can I do this using dynamicMeshDict & mixerFvMesh? What is the appropriate solver? pimpleDyMFoam? I have read that this kind of simulation may not be possible under this development of OpenFOAM. Is this correct? Also, regarding mixerFvMesh, is the setup limited to having the rotor inside the stator (like a pump)? Can it be applied to a case where the stator is upstream or downstream of the rotor i.e. sliding perpendicular to the axis of rotation? Any help on this would be much appreciated. Thanks, Thomas |
dynamic meshing, les, sliding mesh |
Display Modes | |
continue LES simulation after it stopped | holand_us | OpenFOAM | 9 | April 5, 2010 13:52 |
How to determinate turbulence scale in LES (laminar simulation)? | Franciswu21 | ANSYS | 0 | October 22, 2009 13:48 |
LES simulation of bluff body at Re(d)=1200 | arash_nl | FLUENT | 0 | June 1, 2009 14:16 |
LES simulation! | fpz | FLUENT | 0 | March 27, 2005 22:32 |
LES simulation of sonic jet | Jianping | Main CFD Forum | 0 | January 21, 2005 06:52 |
